Question about Hotpoint WMA30 Front Load Washer
Sticking drum There would appear to be something jamming inside the drum. On manually turning the drum it sticks and needs extra force to get it past the obstruction. This results in horrendous noise on spin cycle. How do you get behind the drum??
  • Darragh Jan 27, 2008
    Drum is sticking , feels as if bearing has collapsed.Our machine is 7yrs old
    is is worth repairing it ,and would anyone have you any idea of cost ?
    Thanks
    Mark
SOUNDS AS THOUGH THE BEARINGS HAVE COLAPSED..OPEN THE DOOR LIFT THE INTERNAL DRUM AND FEEL FOR ANY MOVEMENT YOU WILL HAVE TO APPLY A BIT OF EFFORT IF IT MOVES ITS THE BEARINGS.
Posted on Dec 03, 2007
  • 139 Answers
YOUR DRUM BEARING HAS GONE
Posted on Aug 31, 2006
SOURCE:
Broter hl-5170dn in paper jam drum
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot
remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of
the jammed paper from the paper tray
Jul 07, 2011 | Brother HL 5170DN Laser Printer
Not working and the tray keeps popping out a quater way
Something is jammed inside. You can try leaning the PC down toward its face and pressing the OPEN/CLOSE button a few times to try and dislodge the object.....
(Q: do you have kids? This happened to me once after my CD drive was "fed".....)
If the object falls out, you should be OK.
One last thing you can try....
When the tray is sticking at least partially out, lean the PC over as far as you can and pull the tray out fully... you will feel some resistance, but do not force it. When it is fully extended, see if anything is jammed inside it- you may need a flashlight and another set of hands....
If not, the drive needs to be removed to get the object out.
Feb 24, 2011 | Philips (DRD-520012) Internal DVD Drive
Lens sticking and beeping coming from camera.. will not power up. lens grinds, not opening... please help
Typically, a jammed lens is due to foreign matter getting inside it or a gear damaged by some kind of force. The lens is not normally serviceable and would most likely need to be replaced by a service centre.
Apr 13, 2009 | Cameras
Paper jams right before it exits copier
If the plate looks solid, then it's probably right where it should be. It sounds like a sort of ramp that feeds the paper into the fuser.
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Feb 20, 2009 | Canon imageCLASS D760 All-In-One Laser...
Paper jam on back rollers
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Sep 15, 2008 | Dell 1710n Laser Printer
Phaser 8400
The 8400 has a known issue with the plastic that was used for the tilt mechanism on the oiling roller. If you look inside where the cartridge is removed you should see a crack that opens when pressure is applied. The high heat causes this unit to crack. You need that part. Or some good super glue. I have fixed 3 of my 8400's with this same issue.
Good Luck
Nov 27, 2007 | Xerox Phaser 8400 Laser Printer
Drum sticking
take the heater out it will be stuck round that or wraped round the front of the drum u may be able to get @ it if not im afraid u will have to split the drum to get it out if u r not an enginer i would not attempt it good luck
Sep 15, 2006 | Tricity Bendix AW1000W Front Load Washer
Hotpoint WMA30 Front Load Washer Logo
166 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
