Question about HP Designjet Z6100 InkJet Printer
26.0:01 Reseat magenta cartridge - HP Designjet Z6100 InkJet Printer
3 Suggested Answers
gymowner
  • 679 Answers
SOURCE: Ink Cartridge won't reseat
When you put a new refill in an inkjet printer, the brain of the printer sends a small electric charge to the cartridge. Try going into the menu of the printer and check or click on the instalation of a "new" cartridge. It will send the charge to the ink and that may be the problem. If that dosen't do it, then see if you can reset the machine by disconnecting the power and any cables for a minute, and retry it then
Posted on May 14, 2009
  • 96 Answers
SOURCE: Magenta print head reseat.
i'm sorry to be the bearer of bad news but it sounds like your carriage assembly is bad. the slot that holds the magenta cartridge is defective.have the carriage assembly and trailing cables replaced. this should resolve your problem. these parts are becoming harder to find because of the age of the printer. carriage assembly part number is C6074-69388. trailing cable is C6074-60418 making the assumption this is a 36" plotter. also you can try cleaning the contacts on the carriage assembly. good luck!
Posted on Oct 01, 2009
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Supply memory error on screen
If you haven't yet, reseat the cartridges. The cartridges have a small chip on them that is read by the printer. If the chip is bad or missing, you'll get that error.Replace the toner cartridge that is causing the problem. If you just bought the cartridge return it, HP warranties them.
10.00.00 = black 10.00.01 = cyan 10.00.02 = magenta 10.00.03 = yellow
Aug 02, 2011 | HP Hewlett Packard LaserJet 3000dn Printer
Keep getting error message 10.92.02
error 10.92.02 means that there something wrong with the magenta cartridge,
Make sure the cartridge is seated correctly. Reseat it.
There is a little circuit board on the cartridge that feeds info about the cartridge to the DC Controller. Compare the magenta with another cartridge to make sure that that circuit board is present. If it is missing, replace the cartridge.
Power cycle the printer.
If it still fails, you need to get a printer tech to look at it.
Did this cartridge ever work? or is it "new" out of the box?
Feb 10, 2011 | HP LaserJet 3800n Printer
I have a Xerox phaser 7300 that keeps telling me to install or reseat the black cartridge
It is slightly unusual for it to be the black toner cartridge (usually cyan or magenta) but this issue is quite common on the 7300. You can find a lot of information about this here.
Dec 15, 2010 | Xerox Phaser 7300DN Laser Printer
Falal error 173 on oki c5650 after changing fuser unit
Cause:
Resolution:
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
Sep 16, 2009 | HP DesignJet 1050c InkJet Printer
May 14, 2009 | HP DesignJet 5500PS InkJet Printer
Not printing - just replaced ink cartridges
Reseat the cartridges.
Do 3 consecutive head cleanings.
May 02, 2009 | Epson Stylus C84 InkJet Printer
My magenta ink cartridge isn't being recognized.
Check for trash in the way and reseat. Try reseating the magents firs, listen for the click that tells you that contact has been made
Dec 31, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
New Magenta Ink is not recognized after installed
Hi, it sounds that the issue can be caused by a defective ink cartridge that installed or a printhead that can recognize magenta ink cartridge. To identify which causes this issue please try the following:
1. Reseat ink cartridge
2. Replace ink cartridge with a specified ink cartridge for your printer.
3. If above steps wont resolved that issue, please call your printer manufacture and ask for service referral or process warranty options.
Tirzo
Oct 21, 2007 | Epson Stylus CX6000 All-In-One InkJet...
HP Designjet Z6100 InkJet Printer Logo
132 people viewed this question
Seeker5211
Seeker5211
