Question about Dell Axiom 60GB for Latitude D400 (AXD1660) Hard Drive
Primary hard disk drive 0 not found dell latitude d400
2 Suggested Answers
  • 909 Answers
SOURCE: dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
Posted on May 14, 2009
No diagnostic utility partition found to run diagnostics
Think about this for a min.
The Primary hard disk cannot be found by the System.
The Diagnostic Utility is ON the Primary hard disk.....OF COURSE IT WON'T FIND IT...
Since the motherboard is not able to even detect the drive as being present, there is nothing YOU can do to get it 'going' unless you replace the BAD hard drive with a new one.
[PS: I hope you've backed-up any important data....]
Aug 31, 2012 | Dell Latitude C640 Intel Pentium 4-M...
Older dell latitude cpx running XP. yesterday after loading firefox and a few mozzilla add ons .. today I boot to error 0 no primary hard disk found.. bios says no hdd installed ????
Hello, Jay.
Well, as the message indicates, your hard disk drive is failing or failed. Try running your diagnostics to verify (boot and press F2 or F12 repeatedly).
If the hard drive is failing, see if someone locally can help to retrieve your documents and other files by removing the drive and setting up the drive as a slave drive on another computer.
The drive would then need to be replaced. Price the same type of drive but it may not be cost-effective to use another drive in this computer.
Hope this helps.
Oct 18, 2011 | Dell Latitude CPX Notebook
What is the replacement for the 2.5" hard drive in the Dell Latitude D400 notebook?
All ATA-100 disks will work. Pick one
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007605+600003451&QksAutoSugge
stion=&ShowDeactivatedMark=False&Configurator=&IsNod
eId=1&Subcategory=380&description=&Ntk=&CFG=&SpeTabS
toreType=&srchInDesc=
Jul 25, 2010 | Dell Latitude D400 Notebook
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
No bootable devices-strike F1 to retry boot,F2 for setup utillity
Is there a hard disk installed inside the computer? try reconnecting it.
The motherboard, the hard drive, or the connector could be faulty in this case.
Remember to unplug and remove battery if you open the laptop, the hard drive is in most cases in the bottom under a cover with few screws or in some dells its on the side with few screws and comes out from the side instead from the bottom.
May 22, 2009 | Dell Latitude C600 Notebook
I but a dell d600 latitud 60 hdd and 512mb,using it up to a month pluse it was tell me 0 primary hard drive not.
I assume you meant "primary hard disk drive 0 not found"? Have you pressed F12 during bootup and run the HD diagnostics? If you can't run the diags and it does not show up in the BIOS, then you have a bad hard drive.
I've seen this error many, many times on D600s.
Dec 20, 2008 | Dell Latitude D600 Notebook
Hi Kenneth,
If you just bought the laptop, then it is still covered by a warranty. Then all you have to do is contact the seller or directly to dell. This is the fastest and most appropriate way, and usually you will get one-to-one replacement (they will replace your laptop with new one). But, please make sure by contacting Dell.
Regards,
dC
Dec 12, 2008 | Dell Latitude D600 Notebook
D6000 DELL LAPTOP
Do you have any flash drives or external drives connected? If so unplug them and try to reboot. If not check to see if the hard drive is firmly in place sometimes they can come un hooked and that error will appear.
Oct 03, 2008 | Dell Latitude D600 Notebook
HDD prob
The machine should recognize that there is a hard drive there, if it doesn't then the hard drive has crashed or failed. You will have to replace it.
Jun 24, 2008 | Dell Latitude C610 Notebook
Dell Axiom 60GB for Latitude D400 (AXD1660) Hard Drive Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
