The receiver in my airwell a/c is not receiving the signal from the remote. i have tried the other airwell remotes that i have for my other units but it is not the remote that is the problem. where can i get parts for these units. my flat is in cyprus and none of the repairers that have come to see it know where they can get the parts from. the unit is 8 years old
SOURCE: Nad c372 Remote Control
G'Day Bozobob
I have had the same problem which required a replacement motorised pot. I've also had a small cap fitted next to the heatsink on the positive rail regulated supply transistor go pop! Bad smell, protection circuitry operates.
Great amp, great design, poor quality assembly and QC. NAD need to lift their game!
Colin Walker
(30 years electronic repair industry)
Posted on Jan 06, 2008
  • 286 Answers
SOURCE: DV 2150 Remote Control Codes
If it's not a well known brand, you're likely not going to find a code for it. I've heard of Go Video, but I don't think it's a very popular brand. (I could be wrong on this point)
Codes don't exist for every tv/dvd/vcr/surround system.
If the remote you bought doesn't have your dvd player listed, then you're probably out of luck.
If it's a very expensive universal remote (like $50-$100) then you might find either a code or a firmware update for it on the manufacturers website.
If not, try every code the instructions list. If you're lucky, one of them will work. If not, c'est la vie.
Posted on Feb 14, 2008
  • 15 Answers
SOURCE: We have a carrier rv air conditioner with a
check and be sure u have a full 12 volt supply going to the unit check your fuses
Posted on Jan 29, 2010
  • 510 Answers
SOURCE: Remote control receiver unit were is it , and a
This reset for key fob Hyundai coupe year 02 to 04
Turn ignition to position two
Press lock or unlock once
Ensure indicators flash once to confirm reset
This will enable fob providing you have no other faults
Good luck barry
Posted on May 12, 2010
NiHaoAirwell
  • 7 Answers
SOURCE: We have just purchased a universal remote for our
Airwell remote controls (RC) are not coded (so not listed) for universal use.
The only way of using a universal remote control is to learn the new RC by sending the commands piece by piece with a original Airwell RC.
Posted on Aug 10, 2010
Lh d6240. Not receiving signal from the remote control, the technician checked the remote and said has no problem
test this steps and fix it. God bless you
The batteries are dead.
Replace the batteries.
There is something blocking the receptor on the main unit.
Remove any obstructions and clean the area in front of the receptor.
The remote is too far from the receiver or at too extreme of an angle.
Move closer to the receiver (within 23 feet) or change the angle (within 30 degrees) to the receiver.
A fluorescent or other bright light is shining on the receptor on the main unit.
Turn off the light or shield the receptor.
The device has a keylock or lockout feature turned on.
Check the display for a key or lock symbol, then follow the instructions in the device's user manual to turn off the keylock or lockout feature.
Either the remote or the receptor on the device is not functioning.
Use an Intraed Sensor to see if the remote is sending a signal.
If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
If the remote is not sending a signal and you have replaced the batteries, you will need to repair or replace the remote, depending on cost.
Nov 01, 2013 | Televison & Video
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
Visio E3D420VX Remote Control Does Not Work
If the remotes have been tested and ruled out and do not work at even very close range to the set I would suspect the remote receiver in the set is bad---
It is of course inside the set but has to be up front somewhere with a lens--not very large.
Understand that both the remote and the front buttons(or side) both go to the same place inside the set with the manual ones having priority over the remote===remote signal is infrared and is translated inside the set---both that signal and the buttons go to the microprocessor which does the actual work.
If remotes are good something between the lens on the receiver and the micro is bad, the receiver is the common failing point. Not really a lot of parts from where the signal comes in until the micro.
Dec 04, 2012 | Televison & Video
I have dishnet with two TVs connected. The main one works fine no issues. The issue with the TV in the bedroom is that the remote control does not work well. The distance to the base is just a little...
Tries put somthings under the receiver box unit make it higher for a better signal ranges to receive the remote infer red signal to the box.
Mar 22, 2011 | Televison & Video
Panasonic AC Model CS-A28BKP5 remote not working. Remote does not work....Replaced with a new remote however still no joy. Checked remote and is functioning correctly ....unit can be turned on and off...
If receiving signal in unit and calling signal in remote should be functioned properly. If any one of these, defective you can't operate by remote.
In your case, it's receiving signal in PCB is weak or defective. You can repair/replace only that portion. Call repairman to arrange for it. Thanks. Helpful?
Jan 20, 2011 | Heating & Cooling
The Remote Control is not working. I've changed the batteries and get all the functions to light up but it does not connect with the main unit. I have put the main unit into "force" mode amd that...
There is problem of transmission signal.whether indoor receiving sensor or passing signal in remote.
You can check with same type remote to operate the unit. If unit works your remote problem, if not your receiving sensor in PCB problem. That can be repaired. Helpful?
Dec 28, 2010 | LG LS-K1830HL Heat Cool Mini Split Air...
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
We have just purchased a universal remote for our ducted airwell air con - we need a code for it and airwell isnt listed on the remote
I am sorry if ask wha may seem like a few silly questions, but I need some clarification to assist you better.
-Is this a Residential AC Unit?
-If it is a residential AC unit, where is the thermostat located for this unit?
-Do you know if there is a wall mounted thermistor located on the wall in another room or in the room it cools?
I ask these questions, because generally if the fan coil is mounted in the ductwork, then there isn't always a way of controlling it remotely. Generally, it's controlled by hard-wired thermostat.
If you know it was controlled remotely, then you will need to go the website for the Airwell Fan coil and do a search on programming the remote. I'm sorry there is no short cut for this, you will need to obtain the code from Airwell.
Hope this helped... :D
Jun 27, 2010 | Heating & Cooling
Our infrared remote control receiver is making a buzzing sound & the unit will not run on any cycle it's an airwell
Did you or anybody changed something in the indoor unit?
Normally when the unit is making a buzzing sound, the model plug is mounted the wrong way on the electrical board.
Feb 02, 2010 | Heating & Cooling
Remotes won't work
There is a reset button in your remote try to reset it then try the remote to your unit. If it wont work then the receiver board is defective.
Jan 04, 2008 | Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
