Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
Whirlpool Dishwasher power surge results in flashing clean button
Hi, I need the reset sequence that the Whirlpool manual doesn't describe in the owners manual for dishwasher GU2500xtpq6. I'm sure it must have been a power surge as this has happened before an each time a repairman charge is $100. I can't remember the sequence he showed me so if you know it, Great!
  • 1 more comment
  • juliwasson Oct 23, 2008
    Yes, I know what paper you are talking about ... I have discovered the solution to be: Hit the following buttons (below) in this sequence within 5 seconds; then watch for the control panel lights to go on as it will prompt a diagnostic; if you know you don't need the diagnostic, go ahead and hit cancel. Then restart dishwasher.
    Heat Dry - Normal - Heat Dry - Normal
    THx -- JW
  • Anonymous Mar 05, 2009
    I had the same problem only it wasn't a power surge...someone opened it before it was done...hence forth it locked up. I knew there was a sequence. When I called the tech wouldn't give it to me. Thanks you saved me a service call.
    Deb in Denver
  • Kay Caldwell Oct 24, 2013
    This solution just fixed my dishwasher! Thanks!
  • 5,911 Answers
I'm not sure what the sequence would be on your particular model as Whirlpool dishwashers can differ in operaiton. However, if you remove the lower kick panel under the dishwasher door, there should be a tech sheet either directly behind the panel, or tucked inside the door. The tech sheet will list all troubleshooting tips and any fault codes that the owner/operator's manual does not list. This is the SAME sheet the repairman will reference when they come to your home on a service call. Please let me know if you still require assistance. I hope this helps you.
Posted on Oct 22, 2008
Hi there, the power light keeps going off whenever i open or close the door , it sometimes comes on when the door is halved closed but goes off when i lock the door hence i cant get it going, modeldeasis a whirlpool adg6560 , any ideas please ???
Jean louise
Posted on Feb 11, 2010
Whirlpool gold quiet 3 dishwasher flashing clean light nothing works i had to push 2 button and cant remember code to reset unit
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or high temp wash-heated dry-high temp wash-heated dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 28, 2011 | Whirlpool Dishwashers
The start light flashes continuously without interruption. It doesn't pause after 7 flashes. Dishwasher will not run.
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 05, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
We washed the dishes and now the clean light is flashing. When we hit cancel it runs for 2 minutes and continues flashing, why?
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 08, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
The clean light is flashing on a whirlpool dishwasher-model du1048. The manuel says the dishwasher has malfunctioned and to check the heater circuit. How do I do that?
Kevin
Feb 17, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Clean light will not stop flashing
Kevin
Feb 15, 2011 | Whirlpool Gold GU2275XTV Builtin...
My dishwasher is flashing clean and will not stop , no other buttons respond
Kevin
Feb 15, 2011 | Whirlpool Dishwashers
Dishwasher quits running and clean lite keeps flashing.
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
My GU2475XTVY0 built-in dishwasher has the "Normal" light flushing since yesterday morning. We pressed "Cancel" button, other buttons, and finally turned the power off and on, but it didn't do anything. Do...
Hello- The touch control pad is failing and must be replaced. If unit is under warranty, get it serviced. This control is about 125$. Let me know if this info helps. Thanks-Ed
Mar 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher will not run. clean light flashes seven times
I tried the button sequence described by guest #1 but nothing happened.... is there anything more to it?
Jan 20, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
3,481 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
