Question about HP LaserJet 3055 All-In-One Printer
There is an error message
The error message says no paper pickup and says to press the check...that doesn't do anything. I can't copy or print ... any ideas?
I just put a new toner cartridge in prior to this problem.
Thanks for your help!
  • Anonymous Nov 11, 2008
    Says there's no paper, but it picks up the pPER AND SPITS IT OUT AGAIN!
    Sergeant:
    Champion:
  • 275 Answers
Do u get a error code?
Posted on Oct 31, 2008
No paper pickup, Press check
1. Push the paper far inside / use the priority tray.
2. Check for deterioration of the rubber on the main pickup roller (Replace if needed).
3. Ensure that the main paper pickup roller (view inside the printer from the priority input slot - use a torchlight) is rotating when print command is given / 'check' button is pressed after the error message.
4. The printer will make three attempts, one after the other, to pickup the paper (you should be able to hear the sound of main motor and gear train rotating - if no sound is heard the main motor / gear train is bad).
5. If the paper pickup roller does not rotate - a component in the gear train needs attention / replacement.
6. The gear train is behind the formatter inside the right side cover.
7. Service manual can be downloaded free on the net.
Mar 05, 2014 | HP LaserJet 3055 All-In-One Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Paper jam message wont clear and alow printing, I have opened every possible area and there is no paper anywhere. I was printing fine when if gave me the message. the piece of paper it was printing at...
Check if there is a reset, or clear message function. or you may try this one:
1. With the printer turned on, if there is a door for the cartridge, open it.
2. Then, if there is a "Go" button, "Print", "Copy" button, press and hold it for 10 sec.
3. Close the cartridge door or cover. Turn it off then turn it on again.
Please advise what will be the result.
thanks
Jun 23, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Paper doesnt feed
please try to clean rubber rollers that pickup the paper but didn't...
Mar 31, 2009 | HP PSC 2350 All-In-One InkJet Printer
Hp printer won't copy
the ink inside of the cartridges is gelled.
Feb 06, 2009 | HP Office Equipment & Supplies
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Sharp AR-5132 copier won't copy, no error message
okay start by loading a piece of paper on the glass and choosing maual feed and placing a sheet of paper in the manual feed tray and press the start key and see what happens. also on some of the sharp copiers there has been a problem with the print button itself, so i don't know if that may be the case.
Thank You,
Mikey
ps let me know how you make out.
Apr 06, 2008 | Office Equipment & Supplies
** Paper Pickup
Check the paper pickup tray & roller may be its not working. If possible contact the local vendor for printer servicing.
Mar 09, 2008 | HP LaserJet 3390 All-in-One Multifunction...
HP LaserJet 3055 All-In-One Printer Logo
95 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
