Question about NewAir Refrigerators
Ice full light stays on (NewAir AI-130S
The "ICE FULL" light remains on. Therefore, it won't make any new ice.
On the flapper that is pushed down by the ice there is a small magnet. It is on the arm on the back right. It trips a magnetic switch. It has either slipped or fallen out completely.
Posted on Jun 16, 2012
catriver
  • 878 Answers
SOURCE: No ice or water from dispensers
Womers, make sure there is not a lock-out on the dispensor panel. If there is, hold it in for 5 seconds and see if the dispensors come alive. Because both water and ice are not working, I would think you have a dispenser board issue. Catriver..post back.
Posted on Sep 28, 2006
SOURCE: ice maker
We just figured out our ice maker suppot try is broken and won't allow the ice maker to twist the ice out when it flips. We purchased a new support piece on line. I saw your problem which sounded similar to what was happening to ours. If you need it, the part # is DA61-02205A. Good luck.
Posted on Jul 22, 2008
SOURCE: ice machine does not stop
Ice maker won't crush the ice
Posted on Oct 03, 2008
Fixe_You
  • 1800 Answers
SOURCE: Ice maker won't shut off when full
check the Shutoff Arm:
An arm extends away from the ice maker over the ice cube bin. During each ice making cycle, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. As ice accumulates in the bin it prevents the arm from dropping back down. When the arm is high enough, the ice maker shuts off and no more ice is made until the ice level in the bin drops.
The ice maker can also be turned off manually by lifting the arm all the way up into a locked position (shown belowef280e4.jpg
The arm is supported at one or both ends. One end extends into the back of the front support (see photo above). If it is not securely in place, it could cause the ice maker to malfunction. Confirm that the arm is securely in place.
For proper operation, confirm that arm is in the lowered position and that nothing is blocking it from normal movement.
To test the shutoff function, lift the arm up into the manual shutoff position. Recheck the unit later to confirm that no ice is being made.
If unit continues making ice even when the shutoff arm is in the up (off) position, refer to the diagnostic table or for a modular ice maker, replace the control module.
check the Shutoff Switch:
Before testing the shutoff switch, unplug the refrigerator to avoid an electrical shock hazard.
There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. Component units (like the one shown below) usually have exposed gears and don't have holes for test probes.
Modular units do not use a separate shutoff switch. Instead follow this link to view instructions for checking the shut off arm.
Posted on Jan 30, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Posted on Sep 16, 2009
Whats wrong with it?
sounds like something isnt clipped in properly or it isnt sensing that the water is in the reservoir
May 25, 2014 | NewAir AI-200SS Stainless Steel Portable...
No loger makes Ice, Fan Motor does not seem to be working. How can I check it?
use a volt meter and see if there is power to the fan. if so, replace the fan. if not, the board is bad
Feb 20, 2014 | New Air NewAir AI-100S Portable Ice Maker
My NewAir Portable Ice Maker no longer makes ice. It pumps water up into the resvior but the fan motor never turns on and it does not freeze the water. Why is it acting this way?
is the compressor hot? if so, the fan might be dead. the condenser needs air flow to cool down. if the compressor doesn't even turn on, the starter coil (inside the box on the front of the compressor) may be shot.
Portable emerson ice machine
The sensor in the bin that detects the ice to tell if its full could be bad. That or the control board.
May 12, 2013 | Kitchen Appliances - Others
My EdgeStar Full Size Ice Maker IB650SS won't stop making ice
The eye needs to be re aimed at the target directly across the bin. It has to be clean too.
Mar 29, 2013 | EdgeStar 65 lb. Capacity Full Size Ice...
Kitchenaid ice maker full of ice but won't release it
What is the model number of your unit?
Nov 29, 2012 | Refrigerators
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I purchased a koldfront portable icemaker KIM202W from living direct (online) in Austin. The ice full indicator light stays on and will not allow for refill of water. I have read the manual, turned off the...
have you checked to see if there is a ice full bin sensor that may be dirty, iced over, or something similar - there has to be a sensor that will tell the system to shut off when the bin is full and it's got to be blocked by something - Good Luck - Eric
Oct 02, 2017 | NewAir Kitchen Appliances - Others
My newair A1200ss stopped making ice. i tried recycling the unit and it has ample water, but the ice tray just stays in the down position. thanks.
I have had the same problem with two different portable ice makers, the ice tray inside is broken so you will have to send it to them and get it fixed. Hopefully eventually they will make the tray out of a stronger plastic.
Nov 29, 2008 | NewAir AI-200SS Ice Cream Maker
Refrigerators Logo
165 people viewed this question
Top NewAir Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a NewAir Refrigerator Expert? Answer questions, earn points and help others
