Question about Candy CN126 Front Load Washer
Where is the filter on the Candy CDB126 washer dryer?
Ever since washing a blanket that disintegrated in the washing machine, clothes are not drying properly. I was told to try cleaning the filter but i don't know where it is! Please help!
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: I have been using a Candy cdb126 for about three
If the dryer tumbles but does not warm up, you either have one or two blown thermal fuses, a burned out element if it's electric, or a burned out igniter if it's gas.
If one of the two thermal fuses are blown you will not get heat. Thermal fuses blow (and are not resetable, they must be replaced) when the machine gets too hot. Often this is caused by not enough air flow through the machine. Check and make sure your exhaust vent is not clogged. Clean it the best you can to get all the lint, dead mice, bird nests, etc. out. Also make sure air is blowing out of the machine when it is turned on. If not you have a blower problem.
The thermal fuses are located on the element casing. They each have two wires coming out of them.They are about 3/4 inch round with screw ears on the sides so they are about 1 1/2 inch long and about an inch across. With a multimeter, check the continuity across the terminals. If there is no continuity the fuse needs to be replaced.
To check the element(s), you can either visually look and see if it is broken or check the continuity with a multimeter. No continuity means the element is broken. Replace if necessary.
To check for a broken igniter, take out the old one and look at it. If it looks broken or very burned, replace it.
Posted on Dec 14, 2010
My washer/dryer isn't drying clothes
this is all i could find on the internet and that is the manual not sure if its going to be of any help to you but you could go to this link and download the manual and see if it does help you out.
i think its the first one on the page.
candy alise go4w464 washer dryer not drying clothes Google Search
Oct 31, 2017 | Candy Washing Machines
My candy cmd 146 washer dryer
yes, 2 of them. front of the aly trunking on top of the drum. just press the little ceramic centers and it will work again, done mine 3 or 4 times now, bit annoying to be honest lol
Sep 11, 2008 | Candy CN146 Front Load Washer
Candy washer dryer not drying
there is a safety feature which advances the timer to a stop position if it overheats on dry. this is caused by poor air flow.
to cure, take the dryer duct off mand clean of lint. this especially accumulates at the bend where the duct enters the tub.
Sep 05, 2008 | Washing Machines
Drying cycle
Is the drying fan rotating(you should hear this)? Or the watertap closed. It uses cold water to make the steam into condense. If tap is closed, the machine has no water to cool the steam with. Check lint filter.
Jan 22, 2008 | Candy CNW156 Front Load Washer / Dryer
Candy CMD146 Washer/Dryer
This machine has selfcondensing system. The condense water is beeing pumped out with the cooling water. The watertap MUST be open during drying. It also may be caused of overloading. The most W/D combos is just able to dry just the half of a full load in one time.
Jan 10, 2008 | Candy CN146 Front Load Washer
CNW136 Dryer not working !!
lift the lid with the power off and reset the safety stat. look for a and little red button on the metal heater duct on the top of the machine
Jan 08, 2008 | Candy CNW136 Front Load Washer/Dryer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Dryer - acquaviva 1300 - how it works?
the dryer has 2 thermostats if these are blown then the heater wont work but you can check to see if the element is burned out by unplugging your machine opening the top off it the wires that plug into the element replace with a plugged wire with bare wires on the end place each wire into the correct connector and turn the plug on this will either heat the element up or if it doesnt then the element is blown m8
Aug 21, 2007 | Candy AQW130 Front Load Washer / Dryer
Candy CN126 Front Load Washer Logo
132 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
