Question about Sony STR-DB790 Receiver
(VFD)isplay of my Sony STR-DB790 won't light up when turned on.
When I turn on my receiver the display won't light up and stays black like when it's off. This problem also occurred about a year ago but one day the display just went on when I turned the receiver on. After that I had no problems with it anymore ..untill this evening. But this time I don't want to wait it out, I would like to know what I can do about it myself.
4 Suggested Answers
jerryg50
  • 1635 Answers
SOURCE: str-db790
The output stage on one channel may be damaged or there may be a blown fuse for the side with no sound. If a fuse is blown, this is an indication of a fault condition.
Also, before assuming a failure, make sure that all the controls or setups are in their proper settings.
Jerry G.
Posted on Apr 12, 2008
marsrover
  • 682 Answers
SOURCE: Sony STr-DB790 problem
please check your speakers cable for internal short circuit-disconnect all speaker cables and test if everything is fine continue to connect speakers one by one until you find the bad one when you find it change its cable first and test then the speaker itself.if the problem still after disconnection ask for help from good service center.
Posted on Jul 19, 2008
ginko
  • 19396 Answers
SOURCE: Sony STR-D665
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
dunnbiker
  • 8546 Answers
SOURCE: cant get sound through my
Assign the optical input IAW the manual.
Posted on Aug 18, 2011
I've got a sony str-de915, no front display but I have sound. noticed a while back the display letters fading until nothing.
These systems have VFD (Vacuum Fluorescent Display) driven by ASIC ( Apllication Specific IC) replacing the display controller could solve your problem BUT TO BE DONE PROFESSIONALLY
Jun 21, 2015 | Sony Audio Players & Recorders
How can i connect my laptop to a db790 amplifier?
All you need is a 3.5mm Stereo Mini jack to two RCA jacks. Connect this to the line or speaker out of the laptop into anything but the phono input on your sony. The phono input will be over driven and sound bad and possibly damage something in the system. Try using any other unused device input on the receiver.
Feb 16, 2012 | Sony STR-DB790 Receiver
Hi, having a problem with my Sony STR - DB790 amplifier. All my surround sound speakers work fine, but my subwoofer is not. The subwoofer has power and is connected using the co axial cable. The...
RCA cable. It's called RCA when carrying Line Level audio; Coaxial when carrying digital data.
Does the sub work when you run speaker setup? It's in the manual.
Apr 01, 2011 | Sony STR-DB790 Receiver
I was playing some music pretty loud today on my Sony STR-DB790 and then no bang no crackling just strait to protect mode turned stereo off thinking nothing of it and now every time I turn it on strait to...
There is an output load causing the protect to engage, turn unit off and dis-connect the speaker wires from the back of the receiver, this will reset the processor ic. Now power on and turn volume right down, if the word protect stays off it means there is a short in the wires or one or more of the speakers. But if the word protect comes on with the "speakers and wires dis-connected" it indicates a short in one or more audio output ic's and will need a tech to address the extent of damage and cost.
Feb 06, 2011 | Sony STR-DB790 Receiver
My sony str db790 is in protect mode, i have disconnected all the speakers and when i turn it on it goes in to protect mode again. i have connected back 2 speakers that i know have no faults and still it...
Hi Kevin, This may not be a solution but you`ve most likely burnt out the amplifiers, I have the same model and its just burnt out the amplifiers for the second time. I was`nt cranking the volume and it was running my Bose AM 5`s which are very good speakers.Its expensive to repair and not many tech heads will take on anything "Sony". If you do have any luck fixing it please get in touch. *n.crookgto@bigpond.com* Regards, Neil.
Dec 11, 2010 | Sony STR-DB790 Receiver
I have disconected everthing from my reciever and replaced the main fuse but now have this PROTECT mode flashing then the unit shuts itself down.
It indicates a problem with the speaker connections.
Check that all connections are correctly done.
You need to unplug the receiver when checking the connections.
Jan 15, 2010 | Sony STR-DB790 Receiver
Jul 19, 2008 | Sony STR-DB790 Receiver
Ps3
You need to go to SETTINGS, Sound Settings, then choose the correct output for your needs there.
If you have any more questions, just reply to this thread.
Apr 12, 2008 | Sony STR-DB790 Receiver
Str-db790
Jerry G.
Oct 12, 2007 | Sony STR-DB790 Receiver
Sony STR-DB790 Receiver Logo
71 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
