Question about iLO DVDR05 DVD Recorder
ILO DVDR05 RECORDER
Do you know if a TV DVD recorder would also work on a computer?
I was trying to hook a DVD recorder to my computer so that I could make a DVD from my computer as I don't have a DVD recorder on my computer that works?
Posted on Oct 31, 2008
I saw a device that hooks to the computer that allows you to input media from a player (VCR or DVD) to the computer but nothing that works the other way around. What is it you're trying to do?
3 Suggested Answers
SOURCE:
SOURCE: Setting the time on my iLO DVDR05 Recorder
1 Press Setup to enter the setup menu.
2 Press the up/down keys to select GENERAL, press enter, Use up/down keys to selet clock setting. press enter.
3 Move to the field to be edited using the up/down keys
4 use up/down keys to increase or decrease the value of the field.
5 To exit a field using the right/left keys
6 Press return to exit the clock settings menu.
Select time format from the menu and press the right arrow key. Use the up.down key to pick hour mode(12hr or 24 hr).
Thats the instructions from my manual.
Posted on May 21, 2008
SOURCE: DVDR05
Clock always stays on...the ZU even counts the seconds.
Posted on Aug 27, 2008
How can i remove a passcode thats been set but i dont know
Is this a pass code that someone else has set?If so,the only way is a lucky guess,ha,i did it that way one time.if you set it,it should be easy to reset,just go to change passcode.when I have login,i can use password or pass pin.is this the kind of passcode your talking about?or on a debit card?there is a # you can call to change it.
Jan 22, 2016 | iLO DVDR05 DVD Recorder
How do i play a dvd movie in ilo dvdr05 dvd recorder
You may have to connect to a different output until you can change the settings back.
Dec 03, 2014 | iLO DVDR05 DVD Recorder
I have a iLO DVD recorder,it will turn on and show menu on front of unit but I can't get the menu to come on screen of TV.It is model #DVDR05/ZU.. You put a DVD into unit and push play on remote and it...
I have a DVDRo4 model so they may not be the same. I connect 3 wire RCA cables to the DVDR output and to TV 3wire RCA input. I set the TV chan to Aux. I set the DVDR souce button to disc. Hope this works on you unit 05
Nov 22, 2009 | iLO DVDR05 DVD Recorder
I have an ilo dvdr04 recorder. ihave set it to my tv which works ok. yet when I try to play or record a dvd nothing comes up, and the tv stays on. how do I get the dvd to come on?
Push the source button on ilo Remote.The front RCA plugs AV1 the rear is AV2 of ilo.
If you still don't see dvd you are not wired correctly.
Jun 18, 2009 | iLO DVDR05 DVD Recorder
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Ilo DVD recorder Dvdr05
i have the same recorder i picked up for free in a thrift shop,does anyone know what to fix on power supply? it wont display anything..
Jun 08, 2008 | iLO DVDR05 DVD Recorder
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
Dvd player turns on and that's it
I have ILO dvd ro5/zu Burner walmart cheapy and I read Capacitors for power supply go bad and leak there are 2 (fuhjyyu 2200uf 10volt) also it runs very very hot so I put in an old computer fan to cool it down works great now, problems with clock flashing and humming noise while recording and playing back. It still has a little hum but other than that it works great 3-4 years old over 150 dvd's burned.
Sep 29, 2007 | iLO DVDR05 DVD Recorder
iLO DVDR05 DVD Recorder Logo
44 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
