Question about Zebra Eltron LP 2824 Thermal Printer
NEED TO FIND A .LBL FILE FOR LABEL DESINGER FOR BUTTERFLY JEWELRY TAG
NEED TO FIND A .LBL FILE FOR 2824 PRINTER TO USE FOR BUTTERFLY JEWELRY TAGS PRODUCT CODE DON-800999-006
IN THE DESIGNER LABEL SOFTWARE
SOURCE: Printer problem
I called CAM Commerce Solutions, the retail POS software we use, and they were able to fix my problem. I was missing another component of the print program that only CAM Commerce has.
Posted on Dec 18, 2008
SOURCE: ZEBRA TLP 2824 LABEL MAKER PROBLEMS
I've had this problem. I changed the margins and it solved it.
Posted on Jun 09, 2009
  • 31 Answers
SOURCE: zebra lp 2824 faded printing
Many factors affect print quality: Heat settings, speed setting and label face stock quality and type are a great place to start. How old is your printer? How many labels have been printed through it (there is an odometer that tells your this on the config label). Is the printhead dirty? Use > 90% isopropyl alcohol on a cotton ball or microfiber cloth to gently clean the printhead.
I would start by checking the heat and speed settings in the driver - crank up the darkness and crank down the speed a notch or two at a time until you get the print quality that you are looking for. If all of this fails, you may need a new printhead (not too easy to replace on this model). Printheads are made up of an array of resistors. These can loose their electrical resistance over time and require more energy (controlled by the darkness setting) to get the same results as a new printer. Printheads, like labels and car tires are considered a consumable commodity.
Posted on Jan 30, 2010
  • 35 Answers
SOURCE: just one of the double tags is printed on
I assume by double tags you mean 2 labels across the roll.
You need to tell your software that the roll is 2 across.
If using the software that comes with the printer, Zebra designer.
Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
Posted on Feb 16, 2010
ozztech
  • 285 Answers
SOURCE: Zebra TLP 2824 Print Orientation
check on the driver, unther the advance tab, if some seting is tick.
if cant check the problem, install the driver again.
Posted on Nov 13, 2010
Usualy i have problems with this printer because the price tag stick to the film and destroy it, and the price tags to. camn you present me a solution. Many thanks
Either you are heating too much so decrease the heat
or you have problem with your tags, probably you have defective tags with too much glue
Sep 15, 2011 | Zebra Eltron TLP 2242 Thermal Label...
My Zebra printer is skipping three labels
if black bars on the back of tags, go to control panel, printer pref, advanced settings, tracking media should be mark sensing, then if using QBPOS, when printing select
use black bar indexing
Sep 11, 2011 | Zebra TLP 2824 Printer
Tags cannot be printed properly in QB POS Version 8. Printer Argox OS 214-TS
The tag printer used by Qb POS is the Zebra LP 2824.
The argox is not compatible.
Jul 04, 2010 | Intuit Quickbooks POS Tag Printer PC...
Just one of the double tags is printed on
Feb 10, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Zebra label alignment
you can adjust this in the template file for your price tags. how did you create your basic price tag label? in the zebra label creator? if so, make the adjustment there. if you have a .ejf file for your price tag label, you should be able to open it in notepad and add the height in pixel dots with the "q" or "Q" command from the EPL programming handbook. This can be a little tricky, but with some trial and error, you can get it.
EPL2 programming guide:
http://www.zebra.com/id/zebra/na/en/documentlibrary/manuals/en/epl2_manual__en_.DownloadFile.File.tmp/14245L-001rA_EPL_PG.pdf?dvar1=Manual&dvar2=EPL2%20Programmers%20Manual%20(en)&dvar3=2746e
Mar 23, 2009 | Zebra 2746e Thermal Printer
Printer problem
Dec 17, 2008 | Zebra Eltron TLP 2742 Thermal Label...
Changed roll of labels, now it won't print...
Warren
one side of the paper will be sensitive to heat and the other side won't be. If it is thermal paper run a pen without the actual ink part sticking out of the pen or use a key from your key ring in your pocket over the paper the friction should leave marks on the thermal side of the paper.
you may have the paper in with the non thermal side facing the heat printing part of the paper. Or you have the wrong paper.
http://www.microtrade.com.au/zebra-printer-ribbon-suits-tlp2824-plus-label-printer/?gclid=Cj0KEQiAuonGBRCaotXoycysvIMBEiQAcxV0nOLqC5Do2fiZih4Z19jw389fNmbkQXNwgUfYVzkqdSgaAhbc8P8HAQ
ld4028-10a or ld21084 may be the label ? not sure its 40 mm wide not 55 mm or 2.2 inch
Mar 10, 2017 | Zebra LP 2824 (clp2)
Zebra TLP 2824
are you able to give me 2 print dumps? change the printer port to file and post the files content here and I will tell you if it is a config/software issue, it sounds like the software is not setting the label home position correctly(R command)
Nov 07, 2007 | Zebra TLP 2824 Printer
Zebra Eltron LP 2824 Thermal Printer Logo
195 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
