Question about Keurig Coffee Makers & Espresso Machines
My keurig b155 is not brewing, showing "Heating, please wait"
  • 60 Answers
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
Posted on Mar 23, 2010
espressonist
  • 1711 Answers
SOURCE: My Keurig Elite B40 will only brew one cup of
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 15, 2010
bozcro
  • 867 Answers
SOURCE: Hi, My Keurig is heating water
seems like hard water has clogged the small water lines, you need to soak it in clr or other de-scaler available from any hardware store. happend to my cappuchino machine a few times (:
Posted on Nov 23, 2010
  • 3 Answers
So I had this same problem the fix was pretty simple. Air had gotten into the fill line and the pump couldn't pump the air filled line. So to get rid of the air try to brew a cup of coffee (make sure you have a cup under) now cover the over flow at the top of your water reservoir with your finger or thumb. Air bubbles should blow into you water storage tank. Once the bubbles are gone remove your thumb or finger. Now try to brew a cup of coffee again.
--snapshot4
Posted on Jan 07, 2011
heatman101
  • 43501 Answers
SOURCE: The Keurig is not dispensing
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Apr 02, 2011
Press brew nothing happens plus screen cup size selection only shows 10 oz option.
Keurig B155 Manual Online: Section 4 - Troubleshooting. https://www.manualslib.com/
look in the troubleshooting section.
kolbrun
Nov 21, 2015 | Keurig B155
Keurig K150 is stuck in the " Heating Please wait..." screen and won't advance to brew screen? How can I get it pass this to brew screen?
Hi there
I assume that you have checked all connections and cables. Look at the troubleshooting pages to see if this problem is solved there.
If not then there is to restart the machine. Unplug the coffee maker and allow it to rest for a few minutes. Then try again. If this doesn't work work look, there might be a valve that needs replacing or an electrician might need to look at it.
hope for the best
kolbrun
Jan 25, 2015 | Keurig Coffee Makers & Espresso Machines
Shutting itself off
There are a couple reasons that the B70 might stop in the middle of brewing so one cannot be certain. The first one is where there are calcium carbonate deposits on the heating element and as the water in the boiler is agitated during pumping there is inadequate heating from the heating element and the thermostat shuts the brewing off when cooler water rises to the thermostat. Try running a mixture of 50/50 white vinegar through the unit a couple timesxto dissolve the calcium deposits or descale the unit per Keurig instructions. Secondly, it could be a faulty thermostat. If you are not handy, mechanically oriented I suggest buying a new one is best, least expensive. I believe that keurig coffee makers are able to brew 5000 cups without a problem. However our experience is that units with more than 5000 brews are prone to leakage, electricalr problems.
Aug 04, 2014 | Keurig B70 Coffee Maker
My Keurig Elite 40 (B40) beeps continuously when I turn it on.
Heating element may be damaged...return for exchange asap
Mar 05, 2013 | Keurig Elite B40 Coffee Maker
Water runs continuously
shut off valve is dysfunctional or dirt is trapped inside the exit tube.
Feb 21, 2013 | Keurig B155 Small/Medium Office Brewer
My Keurig Elite B40 will only brew one cup of coffee and then turns itself off. The Auto Off button is not lighted. If I turn it back on the Heating light will not come on and the Keurig will turn off...
Good luck
May 10, 2010 | Keurig Elite B40 Coffee Maker
After first cup is brewed, it shuts itself off and
No solution but we are on our 5th replacement from Keurig. Everyone has done exactly the same thing. It worked fine for a few weeks, than started turning off after brewing a cup. Like the problem states, the only way we can get it to work is to turn off and wait 15 minutes or so, then try again. Keurig has been great in replacing our coffee makers, but I really like it to just work.
Jan 23, 2010 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
1,589 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
