Every time I turn my camera on it says "card locked". I won't let me take pictures or download on my computer. I sure didn't lock it on purpose!! The manual doesn't even have an answer....help!!
Every time I turn my camera on it says "card locked". I won't let me take pictures or download on mycomputer. I sure didn't lock it on purpose!! The manual doesn't even have an answer....help!!
the memory card of my camera is blocked, when i want to take a picture the camera show the warning "memory car blocked" what can I do to solve this problem?. Im sure that the memory is good because i tried it in another camera and worked very well. the memory card of my camera is blocked, when i want to take a picture the camera show the warning "memory car blocked" what can I do to solve this problem?. Im sure that the memory is good because i tried it in another camera and worked very well.
You can't post conmments that contain an email address.
The memory card is ok because it works in another camera also i switched the little bottom that is on the side of it and still blocked, i think that is due that the cam intern configuration please i need help with this problem of my camera.
You didn't specify the make and model of your camera, so I'm assuming it uses a memory card of some type. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Or you can use any photo cataloging program, such as Picasa.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Disconnect the camera from the computer then remove the batteries.
To download your pictures, try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Not sure how you are downloading the pictures to the computer but starting from scratch check the SD card to make sure the lock is in the "open" position here is a diagram for that. It doesn't matter that it has Kodak on it, I took this as a screen shot and wrote on it to show the unlock position of that annoying little switch. see more below diagram
Make sure the pictures have been downloaded to the computer at this point as the lock would have prevented this from happening. Now what you need to do is format the card not delete format. The manual I have is a reference check your manual for this procedure. Formatting should be done each time you download pictures to the computer, new memory cards or taking one memory card from one camera and putting it in another. Format, Format and yes format Cheers for now
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
As for the locked card, look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Remove the SD memory card and make sure the little slide lock id pushed forward towards the gold contacts. Then carefully insert it back into the camera so as not to knock the slide lock and close up the memory card door. Turn the camera on and go into your set up menu to format, format the card and you will be able to take pictures. Remember to format the card in the camera after downloading your pictures to the computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SD memory cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
