Question about Dyson Ball DC24 Bagless Upright Vacuum
BRUSH WILL NOT SPIN ON DC24 - Dyson Ball DC24 Bagless Upright Vacuum
  • Official Brand Answer
  • 2,572 Answers
I'm sorry to hear you're having difficulties with your DC24. Your machine is equipped with a safety device which shuts off the brushbar if something jams it. To reset it, please follow the steps shown in the video below.
This should resolve the issue, but if you need any further assistance, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Posted on Feb 08, 2012
4 Suggested Answers
jowen75
  • 5 Answers
SOURCE: just purchased this Dyson dc24
When you removed the brush roller dod you examine the end of the actual roller that is opposite from the removal opening. There is a gear that the roller fits over that may have gotten stripped when it became tangled. Check that the gear has not rounded off and look inside the roller bar to see if the area where the gear fits into may have gotten stripped as well. You might try to operate the vacuum without the roller brush installed for a few seconds just to see if the gear turns. When I say gear, it is actually a somall "post" about 1-2" long that the roller brush fits over. Hope this helps!
Posted on Jan 03, 2011
rockmeister
  • 2047 Answers
SOURCE: New Dyson DC24-brush bar will not spin!
Hello there, the Dyson DC 24 comes with a highly motorised brush bar. First you should check the brushbar for blockages. To do this follow the diagram below.
Switch off and unplug machine before clearing brushbar obstructions. Failure to do so could
result in personal injury. If your brushbar is obstructed, it may shut off. If this happens you will need to remove the brushbar as shown and clear any obstructing debris. Refit all parts securely and press the 'RESET' button.
If this does not work then the problem is from the motor which controls the brush bar. The first and only thing you should check is the belt which connects the motor to the brush bar. When this belt is loose or has fallen out then the brush bar would not spin. If on the other hand the motor does not spin then i am afraid it would be best for you to use the 5 year warranty option provided by Dyson.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Posted on Aug 11, 2011
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson DC24 brush spin but
    Sorry to hear you're having difficulties with your DC24. From your description, it sounds as if you may have a blockage in the cleaner head. The easiest way to check for this, and to clear any obstructions, is to follow the steps shown in our online support guide:
    http://www.dyson.com/support/help.asp?article=1120&product=DC24-ALLFLOORS
    It's also a good idea to wash the filters. Under normal use, this needs to be done at least once a month. You can see the correct way to do this in the video embedded below.
    Hopefully this should resolve your issue. However, if you're still having difficulties, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you and provide the assistance you need.
    Kind regards
    Jack
    Posted on Aug 15, 2011
    Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
    I can think of three things that could be wrong.
    The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
    The internal drive belt is worn, or the nylon bush that it runs on.
    The clutch is worn out.
    The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Dc dyson 24 free repair maule
    About 1,100 results (0.84 seconds) Search Results
      ? 1:55
      https://www.youtube.com/watch?v=akGLQ7UbctY
      Sep 29, 2011 - Uploaded by AskDyson
      DC24's brush bar is engineered to shut off for protection if something jams i. ... How to clear and reset the brush bar of yourDyson DC24 upright vacuum cleaner ... Dyson DC24: How toRepair a Loose and Clunky Ball. ... Dyson Ball DC 25 not locking beater bar brush in place while upright - Duration: 17:09 ...
      How to fix your Dyson Vacuum Cleaner when it loses ...
      ? 7:45
      https://www.youtube.com/watch?v=0vd3ldLXgI4
      Apr 16, 2013 - Uploaded by Chuck Fresh
      How to clean the two filters in your Dyson Ball or Animal Vacuum... troubleshooting computer problems, pc helpline, free pc repair... How to take apart Dyson DC 17 to Clean and Service - Duration: 14:33. n4ktz 178,332 views ... Dyson DC24 - Resetting the brush bar (Official Dyson video) - Duration: 1:55.
      [PDF]Dyson DC24 Manualhttps://www.dyson.co.uk/.../Dyson/.../Manuals/DC24_Manual.pdfDysonNote your serial number for future reference. After registering for your 5 year guarantee, your Dyson vacuum cleaner will be covered for parts and labour for.Dyson DC24 Manual - ManualOwl.comhttps://www.manualowl.com/p/Dyson/DC24/Manual/112339Manuals and user guide free PDF downloads for Dyson DC24. ... I Have A Dyson Dc17, Is There A Fuse Or Reset Button On The Vacuum Motor ... Complete Dyson customer service phone numbers and contact information at ContactHelp.com.Dyson DC24 Multi Floor Instruction pack - Part 914529-01 ...https://www.dyson.com/parts/u/user.../dc24userguide.aspx?...DC2...DysonDyson DC24 Multi Floor: Instruction pack - 914529-01.Buy genuine parts and accessories direct from Dyson.DYSON DC24 USER MANUAL Pdf Download. - ManualsLibwww.manualslib.com > ... > Vacuum Cleaner > Ball DC24Page 2: General Safety Precautions. Do not use with damaged cable or plug. If the supply cable is damaged, it must be replaced by Dyson Ltd, our service agent ...
    Jan 28, 2016 | Dyson Vacuums
    Does the dc24 cleaner head have a drive belt
    This might answer your question. Belt can't be seen but there is some drive from the motor to the brush drive.
    Dyson DC24 How To Replace The Brush Bar Motor
    Support forDC24 Multi Floor
    Nov 02, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
    Dyson DC27 brush drum fails to rotate. Belt is fine.
    Dc27 has a motor to spin the brush. It might be the brush bar motor or the power switch to the brush bar motor.
    Oct 20, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
    New Dyson DC24 ball vac 2nd time using brush stopped rotating when caught on short rug fringe/ no mat`l caught
    Your DC24 is equipped with a sensor which shuts off the brush bar if something jams it. You can reset the machine by following the steps shown in the video below. You may also want to refer to our online Support guide:
    http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/my-brushbar-is-not-rotating/stabiliser-check
    Please note, the brush bar will never rotate when the machine is standing upright, so make sure you recline your DC24 into the vacuuming position before testing it.
    If you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Apr 30, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
    Just purchased this Dyson dc24 today. brush doesn't spin after gettin tangled in a cord. removed the cord from the brush OK. I have several times: removed the brush and replaced it OK. pushed the red...
    Dec 17, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
    My brush wont spin
    hi hckymom. when the brush won't spin it is almost always because the belt is broken. Dyson requires you to buy a new drive belt assembly. Easy to install but expensive....usually about 70 dollars. Joe
    Thanks for choosing Fixya!
    Dec 13, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
    Dyson - Ball HEPA Upright Bagless Ultracompact and Lightweight Vacuum brush wont spin
    Hi have you checked underneath to see if the belt has snapped, you will find it either side of the brush, if so you can obtain a replacement at most retails stores but take the model number and make with you, hope this helps
    Jul 17, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
    Dyson Ball DC24 Bagless Upright Vacuum Logo
    23 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
