Question about Kitchen Appliances - Others
Roper microwave Microwave still has light working , fan working all outside numbers working, but will not heat up food
  • 2 more comments
  • she50 Oct 23, 2008
    HI, Everything works on it except it will it will not heat. The model number is Roper MHE14XMB-0 Serial number TRP4940262. Thank You, Sherrie
  • she50 Oct 24, 2008
    Yes the light comes on the turntable turns . It sounds like it always has , just does not heat up anything.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises? Is it louder or quieter than usual?
  • William Miller
    When you hit Start to cook, does the turntable come on?
    Do you have the model number?
    These answers will help me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • 9,086 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 29, 2008
Model #MCO2212ARB (black) microwave doesn't heat food - fan, light all work well just doesn't heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 15, 2010 | Magic Chef Microwave Ovens
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 6 months...
Small component called a diode. Open up the microwave and try to find a black (usually) component that is most often connected between the magnetron (the thing that heats the food) and the chassis of the microwave oven (ground). I used to make a fortune replacing these! Costs about 5 bucks most appliance supply stores. Make darn sure you get one of the same value.
Apr 06, 2010 | Maytag MMC5000 Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
MIcrowave doesn't heat up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
fdyjhd
Jul 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Outside caseing heating up while cooking`
Also, Please reply back with your brand and model number so we can help you.
Nov 20, 2008 | Sharp R-1480 Microwave Oven
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Dec 30, 2007 | Maytag MMV1153A Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Kitchen Appliances - Others Logo
149 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
