Code H3 on a Sharp AR-122EN
Machine showing H3
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
checkitright
  • 1362 Answers
SOURCE: H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
Posted on Oct 20, 2008
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
  • 990 Answers
SOURCE: We have a Sharp AR-335 and it is giving an error
Hello sir; There is the way to reset;
1, press "program", "interupt", "clear", "interupt'.
2, enter 14 press print.
3,turn power off and back on again.
Posted on May 18, 2009
Get a serial key for a sharp print ar 122en
serial numbers of all Sharp Copiers are located on the rear right-hand side of the copier , on a silver sticker
Feb 23, 2015 | Sharp Office Equipment & Supplies
Tray
sir my machine sharp AR-m420u take code H3-01 whats meen this code......?
Dec 03, 2013 | Sharp AR-M455N Copier
My sharp ar5316 wont work it has the code H@ showing how can i fix it
what h4,h3,h2,all of this is for fuser unit ,press # press interrupt press C press interrupt then put 14 then start ,the machine will off and on again
Oct 15, 2011 | Sharp AR-5316 Advanced Digital Imager...
HI, my copier AR-122EN is not working it shows 4 and H when I press he start button.
From the keypad area press # * C * The machine will enter a diagnostic mode.
Then enter the number 14 as if to make 14 copies. Press start and follow the directions to clear the code.
Mar 11, 2011 | Sharp AR-5316 Advanced Digital Imager...
How to reset sharp ar 122en
Hi, to reset the problem signs or codes, key in the following in this order and a speed of a second per key press;
  • C Auto C Auto, display must go off or blank.
  • Enter desired code followed by Copy key press. Others have sub-codes and will require you to press Copy key again after that sub-code. For example H2,H3, U2 and H4 needs once Copy key press while developer or maintenance signs require pressing 20 then Copy key then 01 then Copy key.
Hope i have adequately answered you.
Jan 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 287 code h3-00
H3-00: Heat roller high temperature detection
Check and remedy:-
Check heater lamp operation with
SIM5-2.
If lamp blinks properly:
Check thermistor and its harness.
Check thermistor input circuit of
control PWB.
If lamp lights and stays lit:
Check lamp control circuits of AC
PWB and control PWB.
Clear the trouble with SIM14.
Jan 06, 2011 | Sharp AR-M237 Copier
Sharp reset developer on ar-122en
I do not understand What is step by step help?
Focus me clearly.This machine setup code is: # interrupt C interrupt.
Dec 10, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
HAVE A SHARP AR-336 WITH A CODE H3-00 HOW DO I FIX THIS
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Apr 21, 2009 | Sharp AR-M237 Copier
27 people viewed this question
jasbo
jasbo
