Question about HP Computers & Internet
Internal Health Amber HP DL380 G4. How to fix it..??
ginko
  • 19396 Answers
SOURCE: ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Posted on Jul 25, 2008
MUKHTAR
  • 2022 Answers
SOURCE: HP DL380 G4 could not boot up. Nothing display as
make sure there is no disk in cd rom drive if there remove it and also check the amber led in front panel which is indicating the problem still if you are not able then open it and check the ram. And the power connector in motherboard and also the cmos battery or reset the bios.
Posted on Sep 15, 2009
  • 20 Answers
SOURCE: HP Dl380 and Dell MD1000 storage unit bought
try mirroring
Posted on Dec 14, 2009
drifterK
  • 4924 Answers
SOURCE: Hp compaq prolaint dl380 g4
if you mean that just shows a bue screen and no task bar or desktop ..this is probably from a virus attack that cause it ..Try to press ctrl+alt+del this should show the task manager and in the task manager run a new tas ...and lunch the windows explorer again ..
or just run from task manager the system restore..and try to restore it to an earlier date that worked..To do that pres those like I said ..and than in the task manager on screen choose file and new task (run) and type system restore..and hit enter ..ths should run it ...choose the date that you know it worked and run it ..If it do not restore you have to reinstall or ..to use it for the moment find the desktop address and add it in the start-up for that run MSconfig and press enter ..in the start menu ..choose normal ..and enter ..and choose restart ..it should get along well again..
Posted on Jun 03, 2010
  • 4 Answers
SOURCE: USE441A02R-ProLiant DL380 G4 HP NC7782 Gigabit
I have the same problem and have seen two possible options for resolution...try updating the NIC's firmware and it could be a motherboard problem that needs to be replaced by hp. If either of the options provides the solution, let me know. I'm in the midst of it. (I've tried updating the drivers, swapping network cables, even feeding the NIC a known connection that gives 1Gbps.)
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=407733&prodTypeId=329290&prodSeriesId=407731&swLang=8&taskId=135&swEnvOID=1005#2995
Posted on Sep 28, 2010
ML350 G3 S/board CPU Error Amber LeD + Internal Health Error
You will continue to get internal error until you add memory. It shouldn't even boot without RAM.
Feb 04, 2013 | HP ProLiant ML370 G4 Server
Unable to boot HP DL380 G4 with display message no signal on the monitor
Just Clear NVRAM (by SW6 maintainance switch )/ else systemboard has to be replaced
Aug 11, 2012 | HP Compaq ProLiant DL380 G4 Server
Amber light shows in HDD of server
reinsert HDD / update with HP Proliant ServicePack latest / else replace HDD
Apr 26, 2012 | HP Compaq ProLiant DL380 G4 Server
Select "F1" to continue with
Replace the HDD of the Amber Colour.
That's it
Aug 21, 2011 | HP Compaq ProLiant DL380 G4 Server
HP DL380 G4 could not boot up. Nothing display as well. What's wrong with that?
Sep 15, 2009 | HP Compaq ProLiant DL380 G4 Server
The left led of is amber" is that fault exist on it?"
If you don't experience any network connectivity problems on that NIC, then you should not worry about this. This is a normal condition.
Apr 06, 2009 | HP ProLiant DL380 G4 Server
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
Computers & Internet Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
