Question about Bernina Sewing Machines
My bernina 807 drop feed is stuck with teeth up I can't turn to get them down.
bargainbox
  • 1388 Answers
SOURCE: bernina 1031
Remove the needleplate and check for a buildup of lint between the teeth, this is the most likely scenario.....clear out all the other lint while it is open, and do it regularly.
A small brush and vacuum cleaner are useful, just remove the bobbin case etc first !!
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 24, 2008
  • 8 Answers
SOURCE: I have a Bernina Aurora
If you remove the metal plate on the bottom of your machine, you can see the workings of the feed dog raise and lower button. With some luck it just might be a screw that came out or it might be a broken spring inside the sewing arm.
Without a service manual or a view of what it should look like inside when it is functioning correctly, at best you would just be guessing. It should be a simple 5 min fix but it is best to take it to a Bernina dealer for proper repair. Good luck, bushvideo
Posted on Sep 27, 2008
SOURCE: I am looking for an instruction manual
Can any please tell me where I can purchase a manual for a Bernina Artista 200 Manual as I accidently threw my away.
Regards Cathy
Posted on Feb 15, 2009
louislevel_2
  • 374 Answers
SOURCE: material won't feed
hi! there,
feed dogs are mechanically connected to shuttle race link.everytime shuttle race rotatate and needle goes up and down the move relative to its timing order.there is control knob on feed dogs to release or goes down permanently not to move,on the right side of machine.if you push down feed dogs go down.try to find this one,if you can't try to see uder the machine if there a loosen parts behind shuttle race holding feed dogs.tighen this up.hopefully this could help you,have a nice day,just rate me thank's
Posted on Apr 19, 2009
  • 17 Answers
SOURCE: How do I use the button hole foot on the Bernina
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
Posted on Aug 15, 2010
Feed dogs do not drop for darn Bernina 831
Old oil has dried and is causing parts to seize. Feed dogs are a frequent indicator of this condition. Stitch selectors also tend to be affected. Eventually, the needlebar will seize and the machine will totally stop.
Wheel on right side that controls the needle up and down is very tight...
Aug 07, 2017 | Bernina Sewing Machines
Bernina 440
The jagged teeth on sewing plate are not moving to move the material forward. U will have to look under the machine to check out the mechanism that is supposed to move them and find the part that is the cause of no transmission of power to the teeth assembly.
Feb 15, 2016 | Bernina Sewing Machines
The feeder on my 6690 won't pull material through
Look in your owner's manual. I'm sure your machine has a reverse feed button but don't know if you can manually disable the feed teeth. If it is so equipped, it doesn't drop the teeth. Rather, it simply causes them to go straight up and down. If the teeth truly stay below the needle plate level, they are likely out of adjustment and need to bereadjusted and raised.
Jan 08, 2013 | Husqvarna Viking 1
How do I get the teeth to grab and advance the material on my very old Bernina 830?
Well there's a number of reasons why it may not be advancing the material. First, ensure that the teeth are completely cleaned-out - get an old toothbrush, or similar with firm filaments and, with the stitch-plate removed and the bobbin door open, give the teeth a really firm clean across the teeth to remove anything in between ... this is especially important if you've been sewing with metallised fabric or thread. If the teeth are nice and clean, check if they are still pyramidal with a reasonably 'sharp' point facing backwards - if the machine is very old and very well used, the teeth might be rather rounded and it may be time that you have a new feed dog fitted ... some of the old machines are difficult to obtain spares, but they're mostly still out there. Most commonly, check how far the teeth of the feed dogs protrude above the stitch plate ... this is a bit difficult to do and should really be done with a proper gauge, but generally they should protrude 1mm above the stitch plate - less than that and you wont get the material to move properly, especially if its fine material. Lastly, it could be the foot pressure that's the problem ... if there's inadequate foot pressure, the material will not be pushed adequately onto the dogs. Again, unfortunately, you really need a proper gauge to set the foot pressure, but if the dogs are clean, in reasonable condition and have 1mm of clearance above the stitch plate, you can try increasing the foot pressure a bit. This is done by opening the top cover and you will see a large-ish flat-blade screw in a threaded tube just behind where the needle bar goes up and down and to the left of the takeup arm. If the screw is rather near the top of the threaded tube, you can try screwing it down (clockwise) maybe 2-3 turns to see if it makes a difference ... of not, dont be tempted to just keep screwing up the pressure ... there's something else wrong. Oh .... and by the way .... before you've done any of the above, I assume you've checked that the feed-dogs are not dropped ! You can drop the feed-dogs to do embroidery etc on the 830 - there's a small round knob below the stitch length control - make sure its turned to the position that shows a tooth pattern and not the cross-hathced pattern and make sure the feed dogs do actually come above the stitch plate when turning the handwheel - if they dont, or moving the feed-dog drop control doesn't make any difference, then the link mechanism is almost certainly jammed (really, really common on old machines that haven't been regularly maintained!). To free that off, you need to remove the free-arm cover and look to the front right side of the mechanics - you'll see a linkage that should turn when you rotate the feed-dog drop control - if this doesn't separate or is permanently separated, whatever you do with the control, you need to give it a drop or two of Bernina sewing oil and gently help it move - once free, that should solve the problem. I cant think of any other reasons !!
Hope that helps !
Nov 16, 2011 | Bernina Sewing Machines
I need a new or reconditioned motor for a Bernina minimatic 807 where do I look? Thanks
Try www.Sewingstyle.com. They carry a lot of parts for new and old machines. If they don't show it on their sight, drop them an email or call them. They may surprise you.
May 11, 2011 | Bernina Sewing Machines
How do I use the button hole foot on the Bernina 807 minimatic?
Jun 29, 2010 | Bernina Activa 130
I have a bernina minimatic 807 (old), and am trying to change the bulb. It is really hard...got it out, in pieces, but it'd be really nice to take the door off...which I think I can if I can lift the top. ...
Oh my gosh--how simple it is:
https://www.youtube.com/watch?v=i4YuJS02jt0
However, perhaps the manual would be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjYqvrshIfRAhXj44MKHQ0TCEMQFgguMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FSupportData%2FOut-of-Print%2FBERNINA_807_810_817_manual&usg=AFQjCNFNJyvVESPeSjAOPQT2cX5Z3rclbw&cad=rja
While you have the machine open, it might be a good idea to apply a couple drops of good quality sewing machine oil or (better yet) liquid Tri-Flow Synthetic Lube to every place where metal rubs against metal. (Slowly turn the handwheel and watch the movement.) Also look for the oil port holes throughout the machine an apply a couple drops in each. Do NOT oil the plastic gears or belts!!! Also, move the stitch selector and feed dog levers and hit those with a little oil too. This will keep your machine happily humming!!! You'll probably notice how quietly it runs afterward!
Mar 11, 2010 | Bernina Bernette Deco 600
My old Bernina 1130 has never given me trouble, but today, it seems like the control for the stitch length stopped working. The feed dogs are moving, but the stitch is very, very tiny. Will this be an...
If you have a drop feed mechanism make sure you have not dropped the teeth down by mistake, make sure you have enough pressure on the foot, remember you should not be able to pull the fabric through by hand if the teeth are up
Nov 01, 2009 | Bernina Sewing Machines
Feed teeth have dropped down
Hi. Benieth the free arm there is a lever that you can switch from left to right. This raises and lowers the feeddogs for normal sewing and darning. Possibly you need to flip that switch lever. If that doesn't solve it then the freearm cover on the bottom needs to be removed and the feeddog mechanism cleaned and oiled. Could be stuck.
Good luck. Hope its the easy fix.
Rick
Jan 21, 2009 | Bernina Bernette 75
Bernina 1031
Apr 23, 2008 | Sewing Machines
Sewing Machines Logo
147 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
