Washing machine stuck in spin cycle, LOUD buzz, smells like somethings burning & wont drain
I heard a LOUD buzz coming from the washer. The washer was still full of water and stuck on the spin cycle. I tried to reset but none of the water will drain. I tried filling it, and it does still fill with water, just not drain the water and it wont spin. It also had a slight burning smell to it when i opened the lid. Please help! Thanks!!
  • 2 more comments
  • crzylaugh1 Oct 22, 2008
    It says Kenmore 90 series. That's all I know. Where can I find a more specific model?
  • Cribbs Oct 23, 2008
    I also have an Indesit machine and have a similar problem except that it does not fill with water, it just goes round and around. I cannot drain it or change it to another programme it is just stuck. Had advice to remove the filter and to check that but it is too difficult to remove, even my strapping ex husband is unable to remove it.
    Patricia Warren
    patricia.warren@airbus.com
  • dark_edgeban Nov 04, 2008
    the washer machine works but when it goes on spin cycle it stops, and it doesnt drain, but i dont smell anything burning
  • grant weatherall May 11, 2010
    wot type of machine
  • 249 Answers
SOURCE: burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Posted on Dec 08, 2007
  • 16 Answers
SOURCE: Washing Machine Problem
If its got a drive belt check that also as something maybe jamming drum from turning.??? If it cant be spun by hand.
Posted on May 19, 2008
  • 112 Answers
SOURCE: Burning smell, loud when spinning, bleach spots
Usually this is due to the tripod mount on the back of the drum cracking. Simply replacing the bearings does not help in most instances. The only true remedy is to replace the drum, along with the front and rear tubs. These are usually covered under warranty but the labor (6-8 hours) is a customer pay unless the unit is very new. Also, it is recommended that you replace the drain pump as well when performing this repair. It is a good idea to get this looked at as soon as possible as more damage can incur. I have seen them vibrate so violently that they break the control boards above the drum. If you give whirlpool an earfull, they may or may not offer some help on the bill.
Posted on Oct 23, 2008
  • 8 Answers
SOURCE: Whirlpool top loader won't spin and I replaced the motor and the coupling too
If your basket appears to be off-center in the opening, and there is evidence of the basket rubbing the front of the plastic tub, then you should check out my post at:
http://www.fixya.com/support/t1254687-duet_washer_very_loud_when_spinning
If this is what happened to your washer, the 'burning smell' you refered to was the plastic tub getting hot from the rubbing of the basket (mine smelled the same way, I originally thought there was an electrical failure).
Posted on Nov 18, 2008
  • 130 Answers
SOURCE: crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Posted on May 07, 2009
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Washer spins but won't drain, electrical smell
HI, the smell is coming from the pump housing. the pump impeller may have slipped of the drive stud, in return, jamming itself in side the housing. this will cause the pump to burn out. Check the following before you replace the pump.
1. Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool washer will not drain
Well i think you should be looking in the filter? Or in the pump. These are the only thiongs that will stop it from draining or spinning! The machine will not spin if it has water in it. It will go into spin inhibit to protect the machine. Check for lost items and then look at pump/filter if nothing then replace the pump then you will be ok.
Jan 02, 2009 | Washing Machines
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Loud noise and smell
It would help to know the brand and model number of the washer. If it has a belt that also runs the pump, something may have gotten into the pump during drain and locked the pump causing the belt to slip.
Oct 07, 2007 | Washing Machines
Washing Machines Logo
812 people viewed this question
Top Washing Machines Experts
