Question about Siemens WFXD8400UC Front Load Washer
F23 siemens s14 washing machine fault code - Siemens WFXD8400UC Front Load Washer
4 Suggested Answers
  • 154 Answers
SOURCE: I have a siemens WM14S794GB washing machine and F23 is flashing
F:23 means that your machine is leaking and should be repaired. This is often a bad seal and if you are competent or know a friend who is they can inspect the source of the leak for you. Needless to say you should make sure that you unplug your machine before attempting any repairs.
Hope this helps you.
Posted on Jun 22, 2010
rickead1
  • 1998 Answers
SOURCE: I have a Siemens WM14S794GB
F-23 is an error due to an internal leak inside of your machine this is usually due to a bad seal between the inner and outter tub also if done by a technician a very costly repair in which they usually charge 4-600 for the repair itself includeing the parts. If you feel you are capable of doing the repair the parts are the inner and outter seal and sold as a kit usually for around 90-110 dollars and you can find the parts at www.marcone.com under contact us there is a 1800 number as well as an overseas number if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations when our chat has fully concluded Thanks Rick
Posted on Feb 21, 2011
SOURCE: Siemens s14-38 washing machine has
We have the same problem. How did you sort it?
Posted on May 09, 2011
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Error code in Siemens s14-79
Hi Lasin,
Search online for "error code *** Siemens s14-79".
Jul 17, 2015 | Siemens Washing Machines
F 23
The meaning of the code depends on the machine's manufacturer.
On Siemens built machines (Siemens, Electrolux, hotpoints etc.) F23 Means that there is overflow and anti flood device has been activated.
In this case:
Disconnect power.
Remove all water at the base of the machine.
Take off the rear panel, or access the drain pump from front door(depends on model).
Check drain hose height and check hose connected to drain pump.
Connect power back.
If problem does not clear after connecting back, replace pressure switch.
With Wirlpool built machines instead (Whirlpool, Maytag, Kenmore etc.) f23 means there is a communication within the CCU and the MCU.
CCU is the main control module (central control unit), and MCU is the Motor Control Unit. MCU is a sealed module located deep inside the appliance, and connected on one side to the motor, and on the other to the CCU. Testing F23 on a Whirlpool is more difficult and requires a technician. In this case all you can do is disconnecting power, if error does not go away call the service number listed on manual.
Regards.
Ginko
May 19, 2011 | Washing Machines
Sep 11, 2009 | Siemens WM14S794GB Front Load Washer
Siemens WFXD8400UC Front Load Washer Logo
27 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
