LEADING EDGE DETECTION ERROR LIFT THE RELEASE LEVER AND ALIGN LEADING EDGE WITH ORANGE LINE
SOURCE: Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Posted on Aug 19, 2008
  • 79 Answers
SOURCE: lead edge detect error
first check the green led on the panel (feeder selection) normally for cut sheet must be on the right side and for roll on the left side.
Posted on Oct 23, 2008
  • 5 Answers
SOURCE: Leading edge detection error
This is caused when the size paper loaded into the machine does not match the size the machine expected. Check the paper size settings to ensure you are using the correct paper setting. This also can be caused if paper loaded does not align correctly.
Posted on Jul 09, 2009
prashanthcl
  • 460 Answers
SOURCE: when i load the roll of paper i get leading edge detection error
paper sensor has been faulty of this printer..
Posted on Aug 20, 2009
Soulvisitor
  • 1113 Answers
SOURCE: trouble
These can be hard to align even when they are new, but I have found there is an issue with the two grip rollers that are on either edge (grips the left and right margin area) of paper inlet at the front, they both consist of a lower roller and upper that the paper is grip with and timed with, I have found although on first inspection of the black rubber upper roller it looks ok, one can find the rubber has stretched and is not moving in time with the center metal hub that actually does the turning.
So do you follow me , the paper is feed into the front slot it is gripped by a set of rollers either side the rubber get old and stretchers, and it slips whilst the centre metal hub turns, this I guess will be happening to one or both of your feed rollers, I have found that removing the rubber and allowing the hub to do the gripping seems to work fine, although replacement of the "tire" is best. There is a lot of models of these babys and this applies only to some of the older designjets, I not sure for sure if yours is one of these ones that do this but thought I'd best tell you about it in case it can help you fix yours.
I'd missed noticing this for a few calls until one day I spotted it, since then I have seen it on quite a few as the rubber gets old and perishes
Posted on Nov 13, 2009
Find shift lock
Do the brake lights work? If not then you have no power to the release solenoid that locks the shifter in park, check them.
Sep 23, 2016 | 2002 Chevrolet TrailBlazer
What causes an acer aspire e14 gives memory error messages on start up
Try this solution... Step 1 - Remove the battery
  1. Slide and hold the battery release latch to the unlock position.
  2. Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
  1. Locate the memory module cover on the bottom of the notebook.
  2. Remove the screw that covers the memory module.
  3. Use your finger or a flat head screw driver to lift the inside edge of the memory module and remove it.
  4. Push both tabs outward simultaneously to release the memory module.
  5. Grasp the memory module by the edges and pull gently to remove it.
  6. Align the keyed (notched) edge of the memory module with the keyed area in the expansion slot. Insert the memory module into the slot at a 45-degree angle until it is seated.
  7. Push the front edge of the memory module down until the retention clips snap into place.
  8. After reseating the memory module, replace the memory expansion cover and then replace the screw.
Step 3 - Replace the battery
  1. Insert the battery into the notebook.
  2. Push the battery into the base enclosure until you hear a click.
  3. Connect the AC adapter and turn on the notebook.
Sep 05, 2014 | Computers & Internet
How do i open the hood.
there should be a lever that is on the bottom edge of dash that is under the steering wheel along the trim. if the handle is broken you can use pliers to grab the cable and pull it to get the hood to realse. if you found all that and i seems to work ok then when pulling the release lever have a friend hit or shake the hood to get it to pop up a little so that you can open it all the way.
Nov 20, 2010 | 1997 Ford Explorer AWD
Pink wire whats it for, it on a pioneer avic-d2
The brake sensor wire (Lt Green) can be simulated with a toggle switch to ground.
Pink (CAR SPEED SIGNAL INPUT)
The mobile navigation system is connected here to detect the distance
the vehicle travels. Always connect the vehicle’s speed detection
circuit or the ND-PG1 speed pulse generator, sold separately. Failure
to make this connection will increase errors in the location display.
Orange/white
To lighting switch terminal
Light green
Used to detect the ON/OFF status of the parking brake. This lead
must be connected to the power supply side of the parking brake
switch. If this connection is made incorrectly or omitted, certain
functions of your navigation system will be unusable.
Violet/white
(REVERSEGEAR SIGNAL INPUT)
This is connected so that the navigation system can
detect whether the vehicle is moving forwards or
backwards. Connect the violet/white lead to the
lead whose voltage changes when the shift lever is
put in reverse. Unless connected, the sensor may
not detect your vehicle traveling forward/backward
properly, and thus the position of your vehicle
detected by the sensor may be misaligned from the
actual position.
Note: When you use the ND-PG1 speed pulse
generator (sold separately), please make sure
to connect this lead.
When you use a rear view camera, please make
sure to connect this lead. Otherwise you cannot
switch to rear view camera picture.
Further detail can be found here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130AVICD2.PDF
Feb 23, 2010 | Pioneer AVIC-D2 DVD Nav/6.5"...
Starting cord won't release
TAKE OFF THREE SQREWS AROUND PULL CORD BUT DONT REMOVE, CARFULY LIFT EDGE SLIDE SCREW DRIVER IN TO HOLD PULLEY WHEEL IN PLACE , TURN OVER AND INSPECT COULD BE DIRT AND DABREE OR ONE OF THE TWO METAL LEVER,S (UNDER) PULLY WHEEL ARE STUCK UNJAM AND RETURN CARFULLY PUT SCREWS BACK IN AND TITEN BUT DONT STRIP IT OUT FROM OVERTITENING
Feb 17, 2010 | Ryobi Garden
HP DesignJet 430 rejecting media
When you load the paper, the carriage edge detector measures exactly where the right edge of the paper is located. Then the paper is rolled forward and the edge is measured again. If there is a difference in the measurements, the printer assumes the paper is not loaded squarely and rejects the paper. After you load the paper and the printer asks you to align the paper, take your time, release the paper with the release lever, and line up the right edge of the paper with the right edge of the paper roll. You might have to do it more than once to get it to load. Some plotters are very sensitive and others are more forgiving.
Sep 25, 2009 | HP DesignJet 430 InkJet Printer
Doesn't recognize paper when loaded
When loading the paper, the edge sensors can be a bit tricky.
Pull the paper through the main guide with the locking plate released. Guide the paper edge it's right along the blue (not over it, just along the left edge of the guide markings on the body of the unit). Pull the paper through and then guide it back so that the lead edge just barely shows up, below the small, black rollers in the main print area. Now lock it down and reboot the system.
Once the print head alignment has finished the unit will pull the paper through and then move it forward and back until it is properly aligned, then cut off any excess it detects.
You should now be able to print. Note: Please do not re-adjust the paper edge after this process is complete.
Aug 09, 2009 | HP DesignJet 1050c plus InkJet Printer
Info on do it tyour self clutch removal on 2001 mustang 3.8
REMOVAL:
  1. Lift clutch pedal to uppermost position to disengage clutch and brake pedal pivot shaft.
  2. Push clutch and brake pedal pivot shaft forward and unhook clutch release lever cable from clutch and brake pedal pivot shaft and allow it to slowly swing rearward.
  3. Raise and support vehicle.
  4. Remove clutch release lever dust shield.
  5. Disconnect clutch release lever cable from clutch release shaft.
  6. Remove retaining clip, then clutch release lever cable from flywheel housing.
  7. Remove starter motor from flywheel housing, then engine rear plate to front lower flywheel housing bolts.
  8. Remove transmission.
  9. Remove flywheel housing back just far enough to clear clutch pressure plate, then remove housing.
  10. Remove clutch release shaft from flywheel housing by pulling it through window in flywheel housing until retainer spring disengages from pivot.
  11. Remove clutch release hub and bearing from clutch release shaft.
  12. Loosen six clutch pressure plate bolts evenly to release spring tension gradually and avoid distorting clutch pressure plate. If same clutch pressure plate is to be installed, mark plate and flywheel so pressure plate can be installed in its original position.
  13. Remove clutch pressure plate and clutch disc from flywheel.
INSTALLATION:
  1. Position clutch disc and pressure plate assembly on flywheel, noting following:
    1. Three flywheel housing to block dowels on flywheel must be properly aligned with clutch pressure plate.
    2. Bent, damaged or missing flywheel housing to block dowels must be replaced.
    3. tart clutch pressure plate bolts but do not tighten.
    4. Avoid touching clutch disc face, dropping parts or contaminating parts with oil or grease.
    5. Align clutch disc using suitable alignment tool inserted in pilot bearing.
    6. To avoid clutch pressure plate distortion, alternately tighten bolts a few turns at a time, until they are all tight, then tighten to specifications.
  2. Install transmission to flywheel housing.
  3. Install engine rear plate to flywheel front lower housing bolts, then connect clutch release cable to flywheel housing and connect retaining clip.
  4. Connect clutch release lever cable to clutch release shaft, then install clutch release lever dust shield.
  5. Install starter motor.
  6. Lower vehicle, then install clutch release lever cable as follows:
    1. Lift clutch pedal to disengage clutch and brake pedal pivot shaft.
    2. Push clutch and brake pedal pivot shaft forward and hook end of clutch release lever cable over rear of clutch and brake pedal pivot shaft.
  7. Cycle clutch pedal several times to adjust clutch release lever cable
Aug 08, 2009 | 2001 Ford Mustang
Leading edge detection error When loading paper into printer this is displayed on the lcd scren
Jul 09, 2009 | Canon imagePROGRAF iPF8000 Printer
Lead edge detect error
Jul 30, 2008 | Canon imagePROGRAF iPF8000 Printer
215 people viewed this question
k24674
