Error code cE or LE, showing lg intellowasher 7kg and it wont start just beeps
  • 311 Answers
SOURCE: LG INTELLOWASHER DD 7KG DOOR LOCK STAYS ON WAY TO LONG
Never heard of that; I would try a new door latch as I have never had a bad control issue with the operation of the door latch. There is no real way to test it. I can getb you the latch if interested. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 29, 2008
  • 4 Answers
SOURCE: lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Posted on Feb 18, 2009
SOURCE: my lg intellowasher 7kg WD-1059 FB will not pump
Pump motor is probally shot, Mine is 4 years old I'm replacing mine again. Yes I've replaced it twice
Posted on Feb 23, 2009
SOURCE: LG Intellowasher cannot complete spin cycle.
My LG front loader will not drain and is displaying OE
Posted on Mar 14, 2010
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
I need a troubleshooting manual for an LG intellowasher 7kg wd-1274FHB which is displaying an SE error code.
LG error code SE LG washing machines displaying error code SE are indicating a "motor fault" although the technical information also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and not too helpful, especially for a DIY repairer so you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you interpret that as buying and fitting a new motor, they are very expensive. You need to at least know how to test a motor for faults and check its connections and carbon brushes (if fitted) if you want to try and diagnose the cause
Nov 23, 2016 | LG Washing Machines
What is CE error code on LG TROMM WM1814CW
According to page 21 of the owner's manual, the following are known error codes: IE= Water Inlet Error, OE=Drain Error, UE=Unbalance Error, dE=Door Error, tE=Thermistor Error, FE=Overfill due to Faulty Water Valve, PE=Water Level Sensor Error, CE and LE=different Motor Errors, and PF=Power Failure.
its a motor error
check the brushes
Jan 03, 2015 | LG WM Washing Machines
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
My LG INTELLOWASHER 7KG 1460FHD stops after 3 min of trying to fill and go back to the start a message came up of LE
'LE' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 22, 2011 | Washing Machines
Drum will not spin
You will need to change the rotor and stator,
Jul 21, 2010 | LG WM1814CW Front Load Washer
What does SE mean on my LG Intellowasher 7kg WE-8074FHB display
Error SE is a sensor problem as per LG support.
you need to change the senser of your machine...
Good Luck!!
Mar 22, 2009 | LG Washing Machines
Washing Machines Logo
175 people viewed this question
Top Washing Machines Experts
