Question about LinxCel Computers & Internet
Ard responds sluggishly through linxcel PS-106 KVM Switch
Model is PS-106. Same keyboard respodns well directly and sluggislhly and not reliably through this KVM switch. Two keyboards tried (Cherry and Lexmark), two KVM switches (same type) tred. Slugish -> keypress registered or not, keypress accepted lately (half a second or more) etc. Happens both in BIOS and after bootup (windows XP tried. ). Is this KVM type obsolete or am I missing something written in a manual I have not available (yet)?
2 Suggested Answers
SOURCE: KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Posted on Sep 15, 2008
Mac keyboard not working through SV211KDVI on windows
Chances are that the distance between the keyboard & the PC computer is attenuating the signal of the keyboard below the threshold (or level) required for interfacing with the PC computer.
Perhaps a shorter KVM cable between the KVM unit & the PC computer could be helpful.
Jan 18, 2014 | StarTech.com (SV211KDVI) 2port KVM Switch
I have iogear miniview kvm (gcs62) keyboard works but mouse conn does not. Mluse is usb mouse with ps/2 adapter. Direct connection via usb works. used to also work with adapter but having tried it with kvm...
USB mouse with PS/2 adapter is not guaranteed to wok with GCS62. This KVM switch is designed to work with PS/2 keyboards and mice only.
When the USB mouse with PS/2 adapter is used in a computer directly, it will surely work, because the USB port can give enough power for the mouse to work. And it can easily convert the signal.
Unlike in KVM switch, the switch serves as a bridge between the mouse and the computer. And the computer does not easily recognize the mouse.
I would suggest to use a regular PS/2 mouse. Or if you want to use USB keyboard and mouse, you need to have a USB KVM switch. Model GCS632U.
Thank you and good luck!
Jan 21, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Have a GCS634U KVM that keeps failing to switch. acts like it lost the keyboard
This GCS634U was designed to work with USB keyboards and mice.
First, you need to make sure that your using a direct USB keyboard (no PS/2 to USB adapter).
Second, connect the keyboard directly to the computer and make sure that it's working correctly.
Third, check the connection between the KVM switch and the computers. Try to connect the USB cables of your KVM into different USB ports of the computers.
Last, try to use different USB keyboard to see if the issue is the KVM or the keyboard.
Try to power cycle the KVM switch. Disconnect the KVM from the computers and make sure that there's no even one cable connected to the computers.
Leave the KVM switch disconnected for 10 minutes, then plug it back in. Reboot one computer first and wait until it's fully rebooted. Turn on the second one untill all computers are fully booted up.
If same problem occur, then you need to contact IOGEAR and have them RMA the device.
Nov 12, 2009 | IOGear GCS634U KVM Switch
Iogear MiniView Micro USB Plus KVM Switch (GCS632U) Problem
The GCS632U does not have any form of display emulation which may cause video problems if the boot up is not done right. What IOGear recommends is when booting up a computer the KVM should stay on that computer until it comes to a desktop. What this does is it allow the KVM to pass the EDID information from the monitor to computer and that should help.
Jul 03, 2009 | IOGear Computers & Internet
Keybrd quits working on laptop after ctl-alt_del to reach login
Repeating keys? This is a common problem for KVM switches if you go beyond the devices' capability. As you can see, GCS62 is a PS/2 KVM switch and it was designed to work only using a regular PS/2 keyboard.
This KVM switch does not support PS/2 to USB adapter. It might work but it's not guaranteed to work correctly. This does not work properly if you have a docking station for the laptop. It might work for couple of months then it would stop.
You smay isolate the problem by following the steps below:
1. Connect the keyboard directly to the computer to see if you will get the same problem.
2. Power cycle the KVM switch by disconnecting it from the computers and leave it unplugged for a minute or two.
3. Avoid using hybrid connection (PS/2 converted to USB) only for testing purposes.
4. If that work, then you know the answer is that this KVM only designed an work correctly with native PS/2 connection.
Feb 22, 2009 | IOGear MiniView GCS62 2-port KVM Switch
KVM hotkey
Jun 23, 2008 | LinxCel PS-121D 2 Port PS2 KVM Switch
Zippy WK610 (USB) does not work through KVM switch
i discovered that that problem is most likely due to the power the switch draws. i have 2 kvm switches,(diferent brands) and bolth do same! company tells me this is a normal condition! i know of no work around at this time. and will post one if i discover one good day! glen.
Mar 04, 2008 | Microsoft Natural Ergonomic 4000
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
KVM freeze, mouse and keyboard failure upon keypress
When ever trouble shooting a KVM that has a problem with one computer always swap the cables at the computer end -- that will tell you if you have a computer or KVM issue.
Nov 07, 2007 | IOGear MiniView GCS62 2-port KVM Switch
Computers & Internet Logo
44 people viewed this question
Top LinxCel Computers & Internet Experts
David Payne
David Payne
Are you a LinxCel Computer and Internet Expert? Answer questions, earn points and help others
