I dropped my xl 1000 1 terabyte external harddrive hitachi while connected to the pc and now wont work making beeping sounds every second does not appear on my computer
Worked fine before dropping it.
JongCur
  • 88 Answers
SOURCE: dropped my external harddrive
Here are some suggestions that might work in a knocked up drive: First,put your drive in a freezer for a day. Place the drive in a sealed bag and get as much air out or vacuum seal if need be. After freezing, quickly insert the drive into your computer. This seems to temporarily reset the heads in the hard drive to allow you to recover and copy some of your important files for a short period. Second, take it to a data recovery service center. They will retrieve the data for you but I would like to warn this will be a bit expensive.
Posted on Apr 23, 2008
Mark_Webber
  • 472 Answers
SOURCE: Lightly Dropped Seagate 100GB External Hard Drive
Your not going to like this, but remember you did ask..
The only way to recover your data is to use a data recovery centre.
You can try this place if you are in the USA
This is not an endorsement of that particular company, but an idea of what you will be dealing with.
For the record, there is no such thing as a light drop when it comes to hdd's. The drive will have recorded the damage as a G-Force that can be read off the controller board at the factory and will not be covered under any warranty either.
Sorry for the bad news.
Posted on Apr 30, 2008
micromend
  • 748 Answers
SOURCE: I dropped my Maxtor external harddrive and now it
What's happened is that the heads have gone past their stops inside the drive. This completely throws off the indexing. Thats why when you turn it on the drive only clicks, it's looking for track 0 but because the index is off it can't find it and then resets. The drive will have to go to a data receovery expert. www.datadoctors.com
Posted on Apr 10, 2009
lock123
  • 6831 Answers
SOURCE: hitachi xl 100 external hard drive is beeping. My
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
  • 10406 Answers
SOURCE: My Hitachi 1000 XL sleeps
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
Testimonial: "My problem is resolv"
Can data recovery be done after cloning another harddrive onto it?
Very Rare Chance to recover all data. you might get some. that too if those sectors of hard drive are not overwritten while cloning.
May 14, 2016 | Toshiba MK1059GSM 1 Terabyte 1TB SATA/300...
My Hitatchi 250GB External Harddrive is not working at all when plugged in to any computer I own/use It makes soft beeping sounds for several minutes and then becomes silent The lights are on, showing
take the hard drive to a computer repair shop but from your description , it may be dead
if it is a disc type hard drive , then continually moving it around is not good for the delicate workings
if it is dead , replace it with a solid state hard drive which has no moving parts and is a lot more robust
May 05, 2017 | Hitachi SimpleDrive Mini 250GB USB 20...
Hard drive clicks, fails to read but powers up. Approx 100GB of music files held and needs recovering. Laptop initially picks up drive on connecting to USB port but then drops out due to read failure.Drive...
Inside that plastic external case of the Hitachi XL 1000 external harddrive, is a regular desktop computer sized harddrive.
It is a SATA type of harddrive.
It is 3.5 inches across in Width. (3 and a half inches)
1 TB in size.
Looks similar to this example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5589521&CatId=2459
On the back end of the Harddrive is where it's power cable, and data cable are attached.
Inside the case of the Hitachi also is a small circuit board. (PCB or Printed Circuit Board)
The SATA harddrive is connected to this small circuit board.
The small circuit board, or Interface PCB , is attached directly to the Harddrive.
Or cables (Wires) are used to connect it to the Harddrive.
The Interface PCB is connected to the computer, via the USB cable that is attached to the Interface PCB.
It is this small circuit board that usually goes bad.
(Unless the external harddrive was on, and dropped. Then the problem is the Harddrive)
There are two solutions;
One, buy an 3.5 SATA external enclosure, and use the Harddrive as an external harddrive again.
Two, install it as a Slave drive in a desktop computer, and retrieve all your information. Burn to disk/s, or flashdrive/s.
When using a SATA harddrive as a Slave drive, there are NO jumper pins to mess with.
DO NOT change any jumpers on the back of a SATA harddrive.
(These are for the factory)
This is an example of a 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
There are no guides to open a Hitachi XL 1000's case, to my knowledge.
It isn't something the manufacturer wants stated.
However opening the external enclosure (Case) isn't that tough. It falls under the same as this model,
http://www.youtube.com/watch?v=hQ_vjyvK28A
Here we see at 3:00 through 5:00, that the Harddrive is attached directly to the Interface PCB.
Just remove the Harddrive from the chassis, and unplug it from the Interface PCB.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 02, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
How do I get my Hitachi xl 1000, 1TB HDD to read on my computer? I turn it on and plug it in and all i get are loud noises from it and the occasional beep, It wont read
  • Does your computer kind of pause and acts like it thinking about connecting to the drive? If you go to the My Computer icon (on your desktop or in Start), and click over it to get the drop down menu, and find/click the "Manage" menu selection. Once the system manager starts, click on the Disk Management. See if your Hitachi drive is listed as "uninitialized" or if it shows up at all. If the former, then consider initializing it (assuming this is a new disk).
  • Otherwise, it sounds like a bad drive. Usually, modern drives produce a either a beep or a snap/click when you first turn them on. Afterwords, it should be a low level hum, some are barely audible. If the loud noises last more than 5 seconds, or sound like something is grinding against something else, you should return it, if it's under warranty.
  • If it's out of warranty and has data, you might consider some company that does data recovery from dead drives. But they tend to be expensive.
Feb 23, 2011 | Hitachi Computers & Internet
I connected my Hitachi xl 1000 external hard drive and my computer is not recognizing any new drive. The drive is working, the light is on, and I can hear him work, but wont be recognised by my laptop.
Try another cable and make sure the connection is in all the way. Also try it on another port or computer. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 01, 2011 | Hitachi Computers & Internet
Hitachi easy drive 1tb problem
I have a 640 GB easy drive. It hit the floor and now when I turn it on, all I get is beeps and hear movement in the harddrive but it does not work
Jul 09, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
My hitachi makes a clicking sound
i'm afraid if you would have damaged the cylinders inside...
if yours hd is under warranty you can try it with a computer repairman...else if would cost you more of the secure recovery of the data in the hd..
thankyou
Aug 31, 2008 | Hitachi 200GB External USB 2.0 Hard Drive
Dell 5100 laptop
if you can hear the one beep sound when booting that means your laptop's system is in good condition. try putting it in the external monitor if still you cant see anything both in external and the LCD just install the old keyboard and press the Fn then external monitor... hope this helps...
Jan 20, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
