Question about Kenmore 75863 Stainless Steel Gas Kitchen Range
Oven problem The oven won't turn on. What might the problem be? Its model number off the bootom drawer is as follows 362.7585690
    President:
  • 878 Answers
In most cases with this model the ignitor has failed. It has to draw a certain amount of amps to open the gas valve. You can test it with a clamp on ammeter to see if it is drawing at least 3.2 amps. Even though some will still glow, they still won't draw enough to open the valve. It's pretty safe to say its' your ignitor giving you the problem. Part number is WB13K0004. This is not a hard job, just remove the oven bottom panel and flame spreader and you will be looking right at it...Catriver, post back.
Posted on Aug 02, 2006
Error code 154 on a bosch oven
The 154 error indicates that the electronic control board that acts as the master control for the oven got too hot. This sometimes happens when the oven vents get blocked. Make sure that there is space between the oven and the wall. Check that the oven is raised a bit above the floor. (The exact clearances may depend on the model.) Next unplug the oven (or turn it off at the circuit breaker). Pull the oven out from the wall and clean the louvers if they are dirty. Check the wiring in the oven for any shorted wires. If the wiring has damage, replace it.
Unfortunately, since this happened in the self-cleaning mode, the electronic control board may need to be replaced. Please add a comment with the model number of your oven, if you would like me to give you the part number you need. The model number is often inside the oven on the door frame. For some models, it's on the inside of the drawer front of the drawer below the oven.
I hope this helps.
Jun 25, 2016 | Bosch Kitchen Ranges
Bottom oven drawer stuck partially open. Cannot close or fully open. Model #316471000
Hello Dan, thank you for your post!
I understand that the bottom drawer of your Electrolux range will not close and it partially open. It is possible that your rail or drawer may be damaged or blocked. I would recommend pulling the drawer out to inspect it. If you pull the drawer out there should be tabs on the side to unlock in order to remove the drawer fully. The model number you have provided is invalid you can locate the model number on the serial tag. The serial tag can be found on the frame of the drawer. I look forward to assisting you. -Matt
Dec 25, 2015 | Electrolux 30" Self-Cleaning Freestanding...
Oven does not work
What is the model number listed inside the oven door area or the storage drawer on the bottom (if it has one).
Jun 05, 2013 | Kitchen Ranges
I have a Whirlpool super capacity 465 gas oven that won't stay lit. It often lights up the first time just fine but then it turns off which is normal but when it tries to relight itself the ignitor...
That sound to me like yall have some carbon buildup on the igniter. On this stove the igniter does 2 jobs. It lights the burner and verifies back to the control that Houston we has ignition. If junk is built up on that ignitor then she won't be sending verification of ignition back to the control. That white residue needs to be removed. NOTE: I don't have your model number I am going by what you describe that this stove is a Direct spark ignition model. If you have a normal ignitor it probably is weak and not drawing 3.5 amps to open the valve. Post a model number (bottom drawer frame)
More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2011 | Ovens
Where can I download a manual for Whirlpool AWM321
You could go to whirlpool.com and click ower center and download a maual for your washer,i tried that but it says the model number couldn't be matched
The following is from the whirlpool website and it shows where to find the model#
Please find the type of appliance you are interested in and click on the link to view the likely location of the model number plate on that appliance here is where the model# could be found
Type of Appliance Model Number Plate Location Range Inside oven drawer, on oven rim Wall Oven Inside oven drawer, on rim Cooktop On underside of unit Microwave Inside microwave, on rim Dishwasher Inside dishwasher, on rim Refrigerator Inside refrigerator, on wall Trash Compactor Inside, on rim Food Waste Disposer Attached to the unit Washer Beneath washer lid, on tub rim Dryer Inside dryer door, on rim.
Jul 29, 2011 | Washing Machines
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
I desperately need a manual for my oven not sure what whirlpool model it is I only have a yellow tag about the automatic end of cooking programmer with the following CODICE;461999751903/A Can you help me
Open the drawer , there is a white sticker with the model number on one of the legs. With the model number I can get you the manual
Mar 15, 2011 | Ovens
If i turn on the oven the pilot burns but no gas
This is a bad gas valve. You will need your model number off this unit to order the correct part. If you will look around the front frame of the oven, there is a serial plate with model number on it. If it has a bottom drawer, it may be on the front frame when you open the drawer. Give us a call with your model number and we'll get the right part out to you asap. 972-859-0929 - We look forward to working with you! Hope this helps!
Oct 03, 2009 | Ovens
Bosch range front glass smashed
open the oven door and look on the sides where the door meets the oven. also slide open bottom drawer and look where drawer meets oven. hope this helps!
Aug 29, 2009 | Bosch HMB402 Microwave Oven
Kenmore 75863 Stainless Steel Gas Kitchen Range Logo
156 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
