Question about Panasonic KX-T7633 Corded Phone
REPROGRAM USER NAMES PASSWORDS
I CANNOT CHANGE USER NAMES AND PASSWORDS TO NEW USERS...
HOW CAN AN INCOMING CALL THAT IS NOT ANSWERED BY SOMEONE IN THE OFFICE BE DIRECTED TO A PERSONS VOICE MAIL.
  • Panasonic Master
  • 2,460 Answers
This will be an incomplete answer because you asked an incomplete question.
The first pat of your question involves access to the voice mail system. You can change it from a PC with software to access the system, or from the system manager's mailsbox (999). WHen the system was installed, you should have been given instructions and a password to that mailbox. You log into the manager's mailbox and select options 6 then 1 then 1 to edit or 3 to reset the password.
Easiest for you is to reset the password and make each mailbox owner do his own name, password, directory characters, and greetings.
There are at least 2 ways to get someone's call to voice mail. The first is by setting call forward at the phone. That's the *710x (VM) # that you dial from the intercom. My voice mail system is at ext 165, so I use *7104165# to send it to VM only when I don't answer. The 4th digit options are 2 for all calls, 3 for busy 4 for no answer, and 5 for busy/no answer. Once you set it, the FWD/DND button functions as a selector.
The second way is, if you know the person is not going to answer, you set up a VM Transfer button.
That's where you take a spare button of the 24, label it, and dial the following. PROG press the button 94 (VM) ENTER. Again, mine is 94165.
The 3rd way involves system programming and has to be set up by the system installer. It involves extension intercept and has timing parameters and destinations that need to be programmed.
I think I got most of your question answered. Post again if you have any questions.
Carl
Posted on Oct 22, 2008
Tip
How to login to other people accounts using protected account
go start
go run
type cmd
type net users
you will see the user account on the command prompt
To change password
type net users "user name" *
type new password
type new password again
note when you change the password for the user you will not be able to see the password when you typing in the new password.
To add a new user
type net users "user name" /add
To delete user
type net users "user name" /delete
on Jan 31, 2009 | Microsoft Windows Vista Ultimate Edition
Tip
To Set Up Your E-mail Account in Microsoft Outlook
1:In Microsoft Outlook, select Tools > E-mail Accounts.
2: On the E-mail Accounts wizard window, select "Add a
new e-mail account" and click Next.
3: For your server type, select "POP3" and click Next
4: On the Internet E-mail Settings (POP3) window, enter
your information as follows:
Your Name
Enter your first and last name.
E-mail Address
Enter your e-mail address.
User Name
Enter your e-mail address, again.
Password
Enter the password you set up for your e-mail account.
Incoming mail server (POP3)
Enter pop.secureserver.net for your incoming mail server.
Outgoing mail server (SMTP)
Enter smtpout.secureserver.net for your outgoing mail server.
5: Click “more settings”. On the Internet E-mail Settings window, select
the "Outgoing Server" tab.
6. Select "My outgoing server (SMTP) requires authentication."
7. If you did not change the SMTP relay section, select "Use same
settings as my incoming mail server". If you changed the user name
and password in the SMTP relay section of your Manage Email
Accounts page, select "Log on using" and enter the user name and
password. The following example assumes you did not change your
SMTP relay section in your Manage Email Accounts page.
8: Select the "Advanced" tab and change the "Outgoing server (SMTP)"
port to 80 or 3535.
9: Click OK.
10. Click Next.
11. Click Finish.
on May 10, 2008 | Microsoft Office Outlook 2003 for PC
.need.a.pass.word.and.user.name.for.face.book.to.log.in.for.incoming.email.messages.to.facebook.in.more
fixya can not help you with a name and password you need to set that up your self.go to the google page and type in..how to setup new facebook name and password.
Oct 24, 2017 | Facebook Social Network
Bought from someone else need to put my nane on it
You have to make 2 changes, One for the computer and one for the user. Here is how you do both:
CHANGE COMPUTER NAME:
  1. Right click my computer and select properties
  2. Select "Advanced System Settings" (skip if win xp)
  3. Select "Computer Name" tab
  4. click "change"
  5. Enter the name of your choice
CHANGE USER NAME:
You cannot change a user account by just changing the name. Just changing the name will make a cosmetic change only and not affect the underlying files/folders in the profile.
1. From an account with administrative privileges, go to Control Panel>User Accounts and create the new Standard user account named the way you want and at least one extra Administrator account. Call the latter "CompAdmin" or "Tech" or the like.
2. Log into the new Standard user account once so the profile files/folders are created and then log into CompAdmin.
3. Now go to Control Panel>System>Advanced>User Profiles>Settings
4. You will see where you can copy user accounts. Copy the old account to the new one from there. Use the Browse to select your new account (C:\Users\newaccount).
5. Log into the new correctly named account and make sure all your stuff is there and that it works the way you want. When you are satisfied, you can log out and into CompAdmin and delete the old user account from Control Panel>User Accounts.
If you wish to log into your new, corrected account automatically, do this:Start Orb>Search box>type: netplwiz [enter]
Click on Continue (or supply an administrator's password) when prompted by UAC
Uncheck the option "Users must enter a user name and password to use this computer". Select a user account to automatically log on by clicking on the desired account to highlight it and then hit OK. Enter the correct password for that user account (if there is one) when prompted. Leave it blank if there is no password (null).
Feb 07, 2014 | Computers & Internet
Changed email address
Which email account ??????
Important information can sometimes be sent to an old email address that you no longer use.
For instance, if you registered a domain name, a website hosting account, a PayPal, or eBay account with an old email address but forgot to update your account when you switched email providers, then messages sent by those sites will be overlooked.
Finding old email accounts is not that difficult, especially because email users tend to use the same user name, or variations of it, for all email accounts.
If you know, or have an idea of what the old user name was, then retrieving, or changing the password is simple, but each email server uses a different user name or password retrieval method.
Call your internet provider and tell them you have forgotten your email account.
Give them your name and account number, found on your monthly statement.
In some cases the Internet provider will want to email this information to you.
Be sure they send the information to the alternate email address which you can access.
You don't want them to send messages to the email address you can't currently access.
The internet provider will ask you the security question you selected when signing up for the account.
If you can't remember what you selected, then the customer service representative may ask for a user name, your address, or the telephone number under which you registered the account.
Reset the password with the customer service representative over the phone.
The representative will help you change the user name if needed and reset the password so you can access the account again.
Yahoo Email
Go to the Yahoo mail page which asks you for your Yahoo ID.
Click on "I can't access my account."
Make the appropriate selection from the choices.
If you choose "I can't remember my user ID" then Yahoo will have you answer the "secret questions" they asked when you signed up.
These questions will be something like: "What was your first car?" or "Who was your third grade teacher?" If you answer coincides with the answer you gave when you signed up for the account.
Yahoo will give you your user ID.
After recovering your user ID, click on "I can't access my account" again and select "I can't remember my password," then click next and you will be taken to a change password screen, where you can change your password.
Start using your old Yahoo email account.
MSN Hotmail Email
Go to the Hotmail, or the MSN ID page, where it asks for your user name and password
Enter your user ID.
Unfortunately, MSN requires you to remember the user ID.
Click on "I have forgotten password"
Choose whether you want your password mailed to you or changed.
Unless you have registered a secondary email, if you choose email then the password will be sent to the account you can't access.
If you want to change password then you will be asked the security questions you specified when you registered the account.
Questions are something similar to, "Mothers birth place?" You may also be asked for your zip code, or address.
Enter a new password.
Enter anew password when the MSN ID page loads again and access your old email account.
Gmail Email
Access the Gmail ID page and click on "I can't access my account."
Choose the appropriate selection from the page that loads.
Options include, "I have forgotten my password" and "I have forgotten my user name."
If you select "I forgot user name," then click on "retrieve user name page," which you will see further down on the page.
Enter the alternate e-mail with which you registered the account.
The user name will be sent to that email.
Select "I have forgotten my password" If you know your user name then choose and click on "retrieve password" page.
Enter your user name on the page that comes up and then answer the confidential question that is asked.
Send password reset instructions to an alternate email and access your old Gmail email account.
Oct 25, 2013 | Computers & Internet
Possible problem with secure http connection of messenger
Yahoo Messenger? It is pretty well protected unless someone hacked your user name or password--someone who knows you?
Consider getting a new user name and password--good idea to change that password every once in a while.
You could contact Yahoo but they often provide little help.
If you are using a router and wireless for the unit--make sure its protected with a security setup and change that password also--so no one can get in and see what you are doing.
Either someone hacked the router or your Messenger name and password.
May 30, 2012 | Dell Computers & Internet
Someone knows my password and i want to change i to make it in private...
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
hope this helps
Jan 22, 2011 | Computers & Internet
How do i set email up in my zte racer
If your looking to set up Gmail you have to setup a new account.
If your looking to set up a hotmail account put the following in when setting up, even if you .co.uk type live.com work for me thankgod
Incoming POP3 Mail ServerSetting :
User Name : user@hotmail.com
Password : your email
password
Incoming Mail Server : pop3.live.com
Mail Box Name : Hotmail
POP3
Mail Box Type : POP3
Security (Port) : SSL always
Port :
995
Outgoing POP3 Mail ServerSetting :
Email Address : user@hotmail.com
password
Outgoing Mail Server : smtp.live.com
Security (Port) : TLS
always
Port : 587
Aug 22, 2010 | Cell Phones
I need help setting up my email on my iphone
1) If this is the first email account you're setting up on your iPhone, tap Mail. Otherwise, from the Home screen, tap Settings.
2) On the Settings screen, tap Mail.
3) On the Mail screen, under Accounts, tap Add Account.
4) On the Add Account screen, tap Other.
5) Select POP and then enter your account information using your keypad. Name Enter your name. Address Enter your email address. Description Enter a description of this email address. The description displays in your email account list on your iPhone. 6) Enter your Incoming Mail Server information.
Host Name Enter pop.secureserver.net. User Name Enter your full email address as your user name. Password Enter your password for your email account. 7) Enter your Outgoing Mail Server (SMTP) information.
Host Name Enter smtpout.secureserver.net. If you need to change your port, use one of the following for your outgoing mail server, depending on the port you want to use:
smtpout.secureserver.net:25
smtpout.secureserver.net:80
smtpout.secureserver.net:3535
User Name Enter your full email address as your user name. Password Enter your password for your email account. Note: The user name and password for your outgoing server is the same as the user name and password your entered for the incoming server.
8) If SSL mode is enabled, under Outgoing Mail Server (SMTP), tap Advanced.
9) Set Incoming Uses SSL and Outgoing Uses SSL to OFF.
Jul 16, 2009 | Apple iPhone Smartphone
Panasonic KX-T7633 Corded Phone Logo
201 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
