Question about Siemens optiPoint 500 Standard Corded Phone
It says you have a message how to check it
How to listen to the messages on siemens optipoint 500 phone. It says you have a message.
  • 5 Answers
SOURCE: Can Siemens optiPoint 500 phone be used at home
An "Optipoint 500" phone can not be used at home!
It is a digital phone, specifically designed for Siemens digital phone systems. Do not plug it in at home. That could damage the phone or may knock your phone line off.
However you can use a "Optipoint 500 IP" phone at home for voice over IP calls. But this would be connected into your broadband router and would connect via the web to your companys Siemens phone system.
Posted on Aug 04, 2009
  • 62 Answers
SOURCE: Features keys
To add an Extension Key, enter [*91] and choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
Posted on Nov 17, 2009
  • 62 Answers
SOURCE: programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
SOURCE: We have an optiPoint 500
it.cc.stonybrook.edu/site_documents/.../guide_optipoint_500.pd
user manual
http://wiki.siemens-enterprise.com/index.php/File:Service_Manual_optiPoint_500_.pdf
Field service manual
If the mailbox is indeed full, and this WILL hold the entire system up, you simply need to remove the old messages. IF it is NOT true, then you have a fault,you need to first try a reset, and if that doesn't work, a re-program if that doesn't work, then the unit has developed an internal fault,and needs to be repaired.
wiki.siemens-enterprise.com/index.php/optiPoint_500
it.cc.stonybrook.edu/site_documents/.../guide_optipoint_500.pdf
Quick reference.
www.phy.hr/siemens/A31003-H1012-C121-8-7619.pdf
Please have a look at ALL links, all have good troubleshooting tips.
Posted on Apr 12, 2010
e-Guru
  • 3917 Answers
SOURCE: I'm trying to connect my new headset with my
Hi
Please check the bellow link for the user guide:-
http://safemanuals.com/user-guide-instructions-owner-manual/SIEMENS/OPTIPOINT%20500%20ADVANCE-_F
Also check this link for connecting 510 Plantronics:-
http://www.headsetsdirect.com/plantronics/510_pairing.html
http://www.ehow.com/way_5272346_plantronics-voyager-user-guide.html
http://www.scribd.com/doc/2367353/Plantronics-Headset-UserGuide
http://www.ehow.com/how_7576585_plantronics-510-operating-instructions.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 20, 2011
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Oct 20, 2014 | Siemens optiPoint 500 Standard Corded...
Our school has a Siemens 500 OptiPoint 500 advance phone that has a greeting one. Can't find out in any of the manuals as to how I can go about changing it. Can anyone out there help me?
We always programme the voicemail to 555. If you have something different change what is below, which is our 'one sheet' user guide from www.dschiltern.co.uk
All Types of Phones
1. Your mailbox number will be the same as your extension number.
2. Default password is 1 2 3 4
3. Voicemail group number is 555 (unless programmed differently)
Before callers can leave voicemail messages you must activate your mailbox and record your greeting message. We would suggest something along the lines of
"You are through to the voicemail of . . . . I am sorry I am unable to take your call at the moment but please leave a message after the tone and I shall get back to you "
To Record Your Greeting Message
1. Dial the voicemail group number (usually 555)
2. Enter your password (default is 1234)
3. Keep pressing 3 to scroll to greeting messages
4. Press 8 to toggle between your two greeting messages
5. Press 0 to change the message and follow the instructions.
To leave voicemail just press 'Release' or hang up.
Responding to Voicemail
On a display phone you will see "You have messages" on the top line and "Display messages?" on the bottom line. Press tick twice to go to voicemail and then enter your password.
On Siemens 'Entry' phone or display phones with a 'voicemail' button, just press this button and enter password when asked.
On ordinary analogue phones you will get broken dial tone. Dial the voicemail group number (usually 555) and enter password.
In all cases you will then be able to listen to your messages.
To delete a message press 0. It will ask you to confirm by pressing 0 again.
Sep 17, 2014 | Siemens optiPoint 500 Advance - Corded...
We have an optiPoint 500 system at our workplace and it is currently saying we are unable to record messages because the mailbox is full. Also, people say the phones are ringing but we are not getting the...
user manual
Quick reference.
Apr 12, 2010 | Siemens Lands Phones
Programmed speed dial - internal calls
Lift handpiece.
Lift handpiece.
Dial [*92]
Dial memory number.
Press the [ü] key.
Press the [ü] key.
Hang up.
Lift handpiece.
Dial [*7]
Dial memory number.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
Nov 25, 2008 | Siemens optiPoint 500 Standard Corded...
Cant seem to find how i change the display name on my Opti500
Usually changed by your Siemens system programmer.
Can be changed by the customer using Manager C software or by using an optiset E Memory Handset.
Nov 12, 2008 | Siemens optiPoint 500 Standard Corded...
Features keys
Sep 17, 2008 | Siemens optiPoint 500 Standard Corded...
Changing the time on a siemens optipoint 500
here you go , follow this on your main phone to reset your time.
press sevice button ( top left )
press *95
press *95 again and press tick
press tick again
press right arrow key until you come to time
press tick key . then press *
enter time (hhmm) then tick key
press main service button and your done.
Jul 12, 2007 | Siemens optiPoint 300 basic...
Siemens optiPoint 500 Standard Corded Phone Logo
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
