How do u find the error code on daikin arc417a3
Got power to the outdoor unit but it's not turning on
farfield
  • 462 Answers
SOURCE: will you tell me the electrical diagram of 12
Remove a door Usually the wire diag is on a cover. I do not under stand why you have so many model numbers. Unless its a generic label used on all the models. and in this case the diagram will most likely be for all them too with foot notes showing the differences. If this helps PLEASE GRADE ME ACCORDINGLY. IF not I need more information.
Posted on Mar 02, 2009
  • 4090 Answers
SOURCE: LG split (3 indoor) LMU360CE
02 Indoor In-Piping Error 2 times OFF
There is a complete guikde to problems on page 66 of users manual. If you dont have one get back to me with your email.
Posted on Aug 02, 2009
  • 47 Answers
SOURCE: i have daikin air con brc1c51/61 showing error code J2.
you cannot fix this mate... you will need a fridge mechanic.. try cleaning your filters id say that's your only chance
Posted on Nov 11, 2009
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Have you found the problem with ya A/C yet PD with the U4 code, if so what was it.
Posted on Jul 27, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a daikin split
Short of gas. Leak test and arrest it. Vacum and do gas charging
Posted on Jan 01, 2011
I have daikin n81 air con, its showing f3 code on the control panel what dose this mean
f3 error is a bad thing, it means excessive compressor temperature in outdoor unit. Overheat condition outdoors. Please find a daikin factory authorized service tech in your area to come check it out. These units are awesome when they work, but when they don\'t, normal HVAC techs tend to not want to touch them. They will try to sell you something else. Or even worse, they want to vacuum and refill them for no obvious reason. A 200 dollar maybe fixit.
The daikin units work more like a tv or a car than the old school air conditioners. They have remote controls and service menus and scan tools and such. A veteran daikin tech can diagnose your system fast and give you a wise estimate of what you need. You may just have a leak, or there might actually be something mechanically wrong outdoors.
I would not push my luck and try to run the unit with this error code. Please don\'t let the magic smoke out of your system.
please mark my answer helpful.daikin ductless
Jan 04, 2015 | Heating & Cooling
How too solve daikin error code c4
c4 error code has nothing to do with outdoor pcb. Use code 41 to check the value of the liquid line sensor and test with mulit meter. Pretty rare fault. Turn the power off for 5
Mins and reboot your system.
Nov 10, 2014 | Cfm Daikin R410a Split System Air...
Fix error code a5
Freeze-up protection. Check that indoor or outdoor heat exchangers are not clogged with dust or dirt. Check filters also. Reset by turning off power to system for 5 minutes and retry. If problem still exists could be a problem with refrigerant levels.
Sep 20, 2013 | Daikin ARC452A9 Replacement wireless...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin reverse cycle air conditioner error U4
Signal transmission error (between indoor and outdoor units) which means a faulty indoor or (more likely) faulty outdoor controller board. Call a tech.
Sep 19, 2012 | Daikin Heating & Cooling
Solution for u2 error
it sound like the outdoor pcb has failed, if your unit is less then 5 years old it will be under warranty. if your unit is a rxd50/60/71jvea it will be a fan motor and pcb
Mar 16, 2012 | Cfm Daikin R410a Split System Air...
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Feb 16, 2011 | Heating & Cooling
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
