MyA4tech Model: G3-280 wireless mouse will not work on my iMac.
My G3-280 wireless mouse will not work on my iMac. i made sure the mouse was on, tried several different USB ports, made sure the nano receiver was inserted and used new batteries but still no go. any help will be appreciated. thank you
jitenok
  • 151 Answers
SOURCE: v220 cordless optical mouse
do this-
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on mic & other pointing device
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this than do this
  1. select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this solution works
Posted on Mar 25, 2008
yooperbud
  • 8637 Answers
SOURCE: MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 28, 2009
SOURCE: wireless mouse not functioning
Being a guy, I started years ago rapping things a couple of times to get them to work - until I destroyed an expensive digital camera!
To my surprise however, I gave my MSK1056 a few gentle taps and, voila, it works.
Thanks
Posted on Jul 17, 2009
  • 2678 Answers
SOURCE: M305 Logitech Wireless mouse with nano stopped working on Laptop
This is a difficult one to answer so lets go through it.
You have a M305 thatrefuses to work and your OS says is returning an error.
You've quite rightly checked the Logitech site and found out that it appears to be a common fault as many people are reporting the same issue.
Logitech have not resolved the issue.
All the above are valid reason for retun to the vendor for replacement/refund.
However you WANT to replace a M305 (a model with know issues) with ANOTHER M305 which will have the same issues as Logitech have not resolved the problem.
I will have to think long and hard before giving a definative reply.
Posted on Dec 29, 2009
SOURCE: re: wireless mouse doesn't work
my wireless mouse has packed up the light is on ive tried new batteries what else can i try
Posted on Jan 07, 2010
New wireless Logitech M320 keyboard works, but it cannot find the wireless mouse nor make it work. What do I do now?
First off, check your drivers and make sure they are up to date with your model. Next check the batteries in the mouse and keyboard, chances are if the mouse is out of juice, the keyboard may not be far behind. Thirdly, make sure you are following the correct procedures stated in the directions for "sync-ing" the mouse and keyboard with the wireless reciever!
Aug 31, 2011 | Logitech Wireless Access Duo Optical...
Mouse and keyboard will not work
Does your imac have the proper bluetooth? If this is a new issue with existing equipment open the bluetooth menu and find devices. You may need a wired mouse to get the proper fix set.
May 01, 2010 | Apple iMac Desktop
After moving, hooked up our Apple IMAC with wireless mouse, cjecked batteries, but mouse will not work.
Use keyboard to open control panel and get to bluetooth using keyboard shortcuts and set to allow all devices and restart.
Apr 05, 2010 | Apple Bluetooth Wireless Mouse m9269zm/a
I have a brand new I-Mac with Snow Leopard. I just bought a Gear Head KBL8000WRBT keyboard and mouse set. I started with the mouse. The computer recognizes it, but won't pair with it.
Since iMacs are not primarily designed to run with equipment like this (They can run it, but the equipment usually says 'No! I don' know what you are!') Try using the apple Magic mouse. (I'm not sure if they have a W/L keyboard.)
Sep 27, 2009 | Gear Head Wireless Bluetooth V 2.0 Desktop...
I am using imac 24
Make sure that BlueTooth is turned on and is discoverable. (System preferences OR via the Bluetooth icon near the time-machine clock in the menu bar. Disconnect your wired mouse and wait a moment or two. You should get a message that no mouse is connected. Switch on your mighty mouse and wait a moment or two.
You should get a message that a mighty mouse has been detected - then follow the on screen instruction.
That's all there is to it.
Sep 14, 2009 | Apple iMac 24" Desktop
My imac 0s 10.5.7 goes blank and restarts mid work. I thought maybe a mouse problem so took off the wireless and put on the one that came with the imac. That didn't solve the problem.
It sounds like either a hardware problem that has been shown up when you installed Leopard, or your Leopard install hasn't gone smoothly.
IS it a new install?
Jul 22, 2009 | Apple iMac 24-inch 2.8GHz Intel Core 2 Duo...
IMac bluetooth mouse won't move cursor
Did you seperately setup the mouse? Even if you have, go into the Bluetooth preferences under System Preferences. Select the mouse & delete it. Setup a "New Bluetooth Device" and select "Mouse." Be sure to press the Reset button for 2-3 seconds to get the mouse into "Discoverable" mode. Your Mac will then setup the mouse automatically.
If this does not work, the Bluetooth chip in the mouse may be defective.
Mar 22, 2009 | Apple iMac 17" Desktop
Can't click and drag
I suspect you have a wireless mouse. When the batteries get low in an Apple wireless mouse, one of the prime symptoms is that click works but drag doesn't, or vice versa. Replace your batteries.
Feb 11, 2009 | Apple iMac G5 Desktop
Wirless mouse is not working
Try another wireless MAC mouse to check to see if it has failed. If the new one does not work, then the wireless receiver in the computer is not responding and will need service.
I am assuming that you checked to see that the mouse set-up is enabled.
Jerry G.
Jun 09, 2008 | Apple iMac G4 Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
