Question about Canon PC-160 Black and White Copier
Canon PC-160 Black and White Copier Problem
Copier turns on but will not progress when button pressed
  • WaterHammer Jan 23, 2009
    Thank You MXM450,
    I did as you suggested....broken plastic link!
    I thought that I would have to scrap the copier
    Thanks again
    WaterHammer
    Scholar:
  • 62 Answers
This is normally cause because there is a broken plastic link between the 'button' you pressed and the actual button. (OR that the actual button, a micro switch is not working properly) you will need to remove that small cover where the buttons are located at and see if the plastic with the spring is actually pushing the switch. try pushing the switch yourself and see if it works, if doesnt then the plastic is not working
Posted on Jan 22, 2009
  • Carlos Perez
    Carlos Perez Jan 29, 2009
    anytime, glad to help!
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
Canon 2030i scanned document in memory - Need to clear
you follow this step :
- press button ADDITIONAL FUNCTION
- press button number 2 and 8 (press simultaneously with two fingers)
- press button ADDITIONAL FUNCTION again.
service mode will come out on the screen
- press FUNCTION on the screen
- press CLEAR
- press R CON
- press OK (bottom right side of the screen)
- swicth OFF the copier
- wait for 3 or 5 second
- swicth ON the copier
GOOD LUCK
if you need more, you can email me
Feb 22, 2013 | Canon ImageRunner 2030I Black and White...
"dowload standby" on canon ir
Basically, this is the mode to reinstall the system software. If powering down didn't clear the message then you will have to do an " All Clear. " Now this will clear out any kind of information you have stored like FAX numbers, Nmaes, etc. Press additioanl function key, then 2, then 8, then additioanl function key again. This gets you into service mode. Press the left arrow until you see #CLEAR, then OK. Press the left arrow again until you see ALL, then press OK. This is what I call a hard copier reset. This should put everything back to factory presets and you will have to put everything you had it before. Now I can't remember if it will need to be powered down after this but it wouldn't hurt. Good Luck.
Sep 17, 2011 | Canon iR 2016i Black and White Copier
Is there a way for me to set my copier to default print black and white? I know this can be managed by each PC but sometime folks forget so i would like to deafult all print jobs to B/W unless otherwise...
TO SET THE MACHINE FOR BLACK AND WHITE ALLL YOU NEED TO DO IS SELECT BLACK ON THE COPIER PRESS THE UTILITY USER KEY THEN PRESS COPIER BUTTON DEFAULT BUTTON THEN SELECT CUREENT SETTING
THIS WILL DEFAULT THE MACHINE TO COPY IN BLACK TO SET PRINTING IN BLACK YOU CAN SET UP THE DRIVER TO PRINT IN BLACK ONLY
Jun 03, 2011 | Konica Minolta Bizhub 222 Black and White...
RESET PASSWORD FOR CANON IR2016 COPIER. I LOST THE PASSWORD.
My Canon C-IR2016 is demanding a Administrative ID & Password.
I did entered the Admin PWD and latter removed it. but can't really
tell what happen that after I restarted the copier, it still requested for
the Admin ID & Password. unfortunately the the details i used before
is not functioning any more. PLEASE I need Help !! thanks
Oct 06, 2010 | Canon iR 2016i Black and White Copier
ImageRUNNER 1023iF Black and White Does this copier enlarge?
It can only enlarge smaller sizes ( like A5 ) to maximum size of A4.
Around the lcd panel is located reduce enlarge button, press one time for auto sizes or twice so that you can regulate in steps of 1%
Jul 20, 2010 | Canon imageRUNNER 1023iF Black and White...
How to change paper size from letter to legal
I dont have info on your PC-920 but almost all canon copiers use the additional function button to gain access to settings. Try selecting the additional function button on the operation panel, then use the - or + buttons to scroll thru your options. When you see Reg Paper Size press ok then use the - or + button to select 8 1/2 x 14 Legal paper then press ok. This is the steps to take on small canon copiers like the ir 1019 and 1023. Your copier is just about the same so this might work. If you have a user hand book that info should be in there. Good Luck.
May 14, 2010 | Canon PC-920 Black and White Copier
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
Printing Black and White
press the reset key
set the copier to B/W
press the * button with a circle around(additional fuctions button)
COPIER SETTINGS
scroll through the pages until you see
STANDARD SETTINGS
press and select store
any problems please get back to me
Thank You
Feb 26, 2008 | Canon imageRUNNER C3220 Color Copier
Canon PC140 light copies
Press button to print does not work
Dec 12, 2007 | Canon PC-140 Black and White Copier
Canon PC-160 Black and White Copier Logo
99 people viewed this question
old marine
old marine
