When I want to install Babylon on my Windows (7) it showes me this message(Error in linking to babyService.DLL)
martyshaw152
  • 157 Answers
SOURCE: stop:c0000221 unknown hard error\systemRoot\System32\ntdll.dll
Hello cluikart,
Here are a couple of links that might give you an idea about the windows stop error. I hope the information on these sites can help you resolve the problem:
1). Annoyances.org: http://www.annoyances.org/exec/forum/winxp/t1030972927
2). Microsoft Support: http://support.microsoft.com/default.aspx?scid=kb;en-us;Q314474
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Posted on Jul 28, 2009
drifterK
  • 4924 Answers
SOURCE: blue screen error
I see ..either teh installation didnt complete the loading of the files..or you didnt format the Hdd proper...try to reformat it in the NTFS normal mode...and change the installation cd ..cause in the proces there might have been a file it couldn't copy ..and skip it ...keep trying cause sometimes it does that ...if the server went fine ..this means that the HDD its ok ..and the problem is the installation disk ...with xp on ...
Posted on Aug 04, 2009
richard191
  • 691 Answers
SOURCE: laptop wont start. error message..Isass.exe-Bad
1. boot in Safe Mode (F8) and rename DNSAP1.dll as DNSAP1.old
check in case the 1 is an I
try a normal boot. 2. boot in Safe Mode and select "Last Known Good Configuration", or 3. boot in Safe Mode and select Command Prompt and do a System Restore as detailed at: http://support.microsoft.com/?kbid=304449 let us know what worked for you...
Posted on Nov 11, 2009
  • 2973 Answers
SOURCE: Display Adapter error (ati3duag.dll) after installing Windows 7
The following link tells you all about blue screens. Please read it carefully and do what applies in your case.
http://supportapj.dell.com/support/topics/global.aspx/support/dsn/en/document?docid=356576
Posted on May 12, 2010
SOURCE: I keep getting an error saying: propsys.dll Missing
http://www.fix-all-dll-errors.com/propsys.dll/
You can find it here...just follow the link.
Posted on Feb 21, 2011
Missing binkw32.dll
Download binkw32.dll from link and save it to your Hard Drive.
2. Copy binkw32.dll file to C:/windows/system32
3. Overwrite if asking.
4. If you still getting error - copy the dll file also to your software/game folder.
http://www.dll-files.com/dllindex/dll-files.shtml?binkw32
scroll down and click DOWNLOAD ZIP-FILE
Nov 06, 2013 | Microsoft Windows 7 Home Premium for PC
Install windows 7
Hello
The file "uncdms.dll" is associated with Windows Desktop Search. This is not required for installing Windows 7.
I would suggest booting the computer, ignore the "cannot find uncdms.dll" error message. Go to CONTROL PANEL, ADD REMOVE PROGRAMS or PROGRAMS AND FEATURES and uninstall Windows Desktop Search.
Reboot the computer and verify the error no longer appears. Once this is verified, you can continue with the Windows 7 install.
Nov 02, 2013 | HP Compaq Presario SR2010NX PC Desktop
Msvcrt.dll error message(Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
Two possible solutions.
Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 23, 2012 | Microsoft Windows XP Professional
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Order Number:246889. I have not received my answer. Problem is a DLL ERROR ~ not printer. littlecaesar@atc.cc My problem is a script error (IE frame.dll error) Please give answer by email promptly !!
  1. Restart your computer unless you've already done so. The ieframe.dll error might be a fluke and a simple restart could clear it up completely.
  2. Install the latest version of Internet Explorer. No matter if you're missing ieframe.dll or if you're receiving a browser error message about it, reinstalling or updating to the latest version of Internet Explorer has resolved many user's issues with ieframe.dll.
  3. Using Visual Basic 6? If so, change the reference for Microsoft Internet Controls from the existing ieframe.dll to shdocvw.ocx. Save your project and then reopen it.
  4. Restart your router, switch, cable/DSL modem and anything else that's used to communicate to the Internet or other computers on your network. There may be an issue in one of these pieces of hardware that a simple restart could solve.
  5. Scan your entire computer for viruses. Sometimes, the ieframe.dll error will show up when your computer is infected with certain kinds of viruses. Use your antivirus software to do a complete system scan for virus infections.
  6. Disable Windows Firewall in Windows XP if you have another firewall installed. Running two firewall applications at the same time can cause problems so if you have a firewall program installed like ZoneAlarm, Norton Personal Firewall, Comodo Firewall, etc., then you should not be running Windows's built-in firewall simultaneously.
    Note: Even if you're positive that the Windows firewall is disabled, check again. Some Microsoft security updates have been known to re-enable the firewall automatically even if you have an existing firewall enabled in another security software program.
  7. Update all non-Microsoft firewall and other security software on your computer. Certain security updates from Microsoft have been known to cause issues with security software from other vendors that those vendors are responsible for resolving. Check their websites for updates or service packs and install any that are available.
    Note: If you're already running a fully updated version of your security software, try uninstalling and then reinstalling the software instead. A clean installation may stop that nagging ieframe.dll error message.
  8. Install any available Windows updates. It is true that some previous updates from Microsoft may actually cause some ieframe.dll errors, but installing more recent updates, especially those to the Windows Update software itself, may help resolve the problem.
  9. Clear the temporary Internet files in Internet Explorer 7. Some ieframe.dll issues may have to do with problems accessing existing temporary Internet files.
  10. Increase the frequency that Internet Explorer 7 checks for new versions of web pages. If the default setting is too infrequent and there are issues with certain pages, you may see ieframe.dll and related errors.
  11. Disable Internet Explorer 7 add-ons one by one. One of your installed add-ons might be causing the ieframe.dll issue. Selectively disabling them will show you which one, if any, is causing problems.
  12. Set Internet Explorer 7 security options back to their default levels. Some programs, even some updates from Microsoft, will sometimes make automatic changes to your Internet Explorer 7 security settings.
    Incorrect or overprotective security settings can sometimes cause ieframe.dll issues. Returning these settings to their default levels may correct your issue.
  13. Move the IE7 Temporary Internet Files Folder to its Default Location in Windows XP. If the Temporary Internet Files folder in Internet Explorer 7 has been moved from its original location, plus both Protected Mode and the Phishing Filter are enabled, the ieframe.dll error will occur.
  14. Disable the Phishing Filter in Internet Explorer 7. This isn't a great long term solution if you don't have another phishing filter installed, but disabling IE7's phishing filter has been known to correct ieframe.dll issues in some situations.
  15. Disable Protected Mode in Internet Explorer 7. The Protected Mode feature in Internet Explorer 7 can, in some very specific situations, be involved in generating an ieframe.dll error message.
Dec 12, 2010 | Microsoft Windows® Vista 64-bit Business...
I am not able to install POP sands of time on my laptop (windows 7 premium) it shows some error related to some dll installation please help
Does the error say that the dll is missing? Then it's simply a case of installing the required dll onto your PC. For a good guide which shows you how to find the required dll then install it, go to http://www.makeuseof.com/tag/how-to-fix-missing-dll-file-errors/
Aug 17, 2010 | Ubi Soft Prince Of Persia: The Sands Of...
I can't change my background
Hi
Download shell32.dll from the following link, and then type "regsvr32 shell32.dll and press Enter" at Run Command in Windows 7.
When you click the following link a page will open, Click Download shell32.dll to download the file.
http://www.dll-download-system.com/dlls-s-/shell32.dll.html
If you face any issue, please let me know.
This solution is absolutely FREE, please rate and give your feedback.
May 10, 2010 | ASUS P5PE-VM Motherboard
//ieframe.dll/dnserror.htm
There are many possible causes for the error you are getting. try these steps.
Still having the issue try the fix at this link HERE
Apr 16, 2010 | Dell Inspiron E1505 Notebook
Dll fix
have you complete the installation fully? you need to make sure it complete.. you may want to read below link to have more understanding about dll error...
http://etech.maiila.com/repair-kernel-32-errors-and-fix-dll-file-error-messages
hope this helps...
Nov 05, 2008 | Ahead Software Nero 6.3 Reloaded (60096)...
Computers & Internet Logo
259 people viewed this question
David Payne
David Payne
