Question about GE Washing Machines
Sanyo washing machine ASW-82HT won't rinse and drain
  • 6 Answers
SOURCE: won,t drain on rinse cycle
I had this same problem. I replaced the computer and the relay boards without luck. I found it was the FILL VALVES! Apparently when the washer changes cycles it expects water to fill the tub to a certain level. If the valves are not opening and water not filling the tub will cause the computer to just wait and wait and wait and wont advance to the next cycle.
Posted on Dec 19, 2011
  • 5 Answers
SOURCE: My washing machine is SANYO ASW-90WRTP. showes E4
Check on the machine there is a schamatic and it has error codes on it. it may be on the in side panel.
Posted on Oct 11, 2009
Testimonial: "cool thanks for that just empty the tub then will check for skidmatics"
kapishtech
  • 2272 Answers
SOURCE: my sanyo washing machine does
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
  • 1082 Answers
SOURCE: Would you have a user
http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
SANYO Owner ManualsTo find an Owner Manual for a SANYO product, enter the model # of the product below.
Please Note: We are in the process of upgrading the Owner Manual search to also include discontinued product documents. Please check back in a week or two if you need an Owner Manual for an older SANYO Product.
Model # ASW-F6OAT
Search Results
Sorry, could not find any documents that match your search criteria
Posted on Feb 21, 2011
  • 6277 Answers
SOURCE: my washing machine is SANYO
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 22, 2011
My washing machine wont spin
Sounds like the belt broke on your washer.
Easy to replace and not that expensive.
Mar 09, 2015 | Washing Machines
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
Washer will fill and drain but won't wash and rinse
Check for a modular unit in the machine that controls the wash action of the machine. If it has malfuctioned there will be no power for the motor. Check with the spares departtment if your machine has this unit
Mar 02, 2013 | Haier HLP21E Top Load Washer
How to open child lock on sanyo asw-a85ht washing machine
Apr 07, 2012 | Cars & Trucks
Washing machine won't rinse and the water won't drain out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2011 | Washing Machines
Maytag Epic Z won't Drain after rinse cycle.
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Would you have a user manaual for a Sanyo ASW-F6OAT washing machine? gusov@mcdermott.com
Model # ASW-F6OAT
Search Results
Feb 21, 2011 | Washing Machines
SANYO WASHING MACHINE ASW F 950 T DISPLAY E A FAULT CODE
I NEED TO FILTER ASW-F950 T,I AM FROM IRAN.MY EMAIL IS BEHAVARD@GMAIL.COM
Dec 14, 2010 | Washing Machines
Washing Machines Logo
571 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
