Question about Maytag MSD2758G Side by Side Refrigerator
NO ICE IN ICE MAKER
HOW TO GET ICE MAKER FIXED? NO ICE FOR TWO DAYS.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
If water valve good change icemaker
Posted on Apr 06, 2009
Why does my control panel show er 1f
Had the same problem with my Kenmore Elite Series Refrigerator. Upon searching for the answer the closest and simplest answer was a faulty fan specific to the ice maker compartment. This fan is suppose to regulate the humidity in the ice maker, but sometimes the humidity becomes too high and that causes the fan to freeze. (A tell tell sign is when your Ice Maker shoot freezes up, or water begins to drip from the Ice Maker and puddles up in the catch tray or on the floor in front of the Refrigerator). When the fan becomes frozen, that causes the 1F error display to come on. There was also a second reason that was consistent with a faulty circuit board, but that did not match as closely as the faulty fan.
Most answers directed you to replace the fan...but I gave this a try first, and by the way my option has solved my problem fan for over two years now. Simply .. open the refrigerator door and turn the Ice Maker off. Then take the ice tray out and dump any remaining ice and clean and dry off the tray and the ice shoot that the ice drops through into your glass. Leave the Ice Maker off for 3-5 days, giving the fan enough time to thaw and dry out. You will have to live with the inconvenience of no Ice Maker for that amount of time .. but you can do that rather than paying an enormous fee to have it serviced in home (unless you're still under warranty). After 3-5 days has expired simple turn the Ice Maker back on. If by any chance this doesn't work..try it a second time but leave the Ice Maker off 5-7 days. Honestly, this should solve the problem. Mine is still working flawlessly. God Bless
Dec 17, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Newly installed ice maker two days old, not dropping ice, frididaire refridgerator
Ice maker under warranty have them look at it will not cost you anything.
Aug 29, 2014 | Kitchen Appliances - Others
106.57029 ice maker intermittent
there is usually an ice overflow switch or electric eye
sensor telling the ice maker that the bin is full. Something
may be obstructing this.
Nov 08, 2013 | Kenmore 57029 Side by Side Refrigerator
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
Ice maker not making ice
a few things, was the ice maker working before repair?? generally the ice maker need to "cool" before making ice, usually give 24 hrs to start producing ice. next perhaps the tech shut off water supply never turned back on??? bottom freezer, perhaps he had to remove the ice maker to remove the back wall of freezer and never reconnected wire harness to the back wall.
Nov 17, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker
ice tube for ice maker keeps clogging with ice . I repeatedly remove and clear it only to find it freezing again. This only happens when the ice maker is turned off for a couple of days.
Oct 18, 2008 | Frigidaire FRS6R5EMB Side by Side...
Ice maker stopped working and no Water in Ice maker,,,
I had this same thing happen and I just fixed it! After returning from a long trip, I threw out the old ice (now mostly shrunk), but no new ice was being made. The tray where the ice is made was completely empty/dry (maybe any ice cubes there had "shrunk" away to nothing as well? perhaps part of what keeps the freezer "frost free"?).
So I filled the tray with water using a small measuring cup -- which is what the manufacturer suggests when the refrigerator is new. Now it's making ice again just fine! This might or might not work for you, but trying it won't cost you anything.
Aug 27, 2007 | KitchenAid Superba Architect KSCS25INSS...
Maytag MSD2758G Side by Side Refrigerator Logo
120 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
