Question about Boating
How old is a minn kota trolling motor model# 55c serial #14428
I bought a older minn kota electric trollling motor model #55c the serial # is 14428. The motor runs great is in almost new conditon. It has 55lb. thrush forward, reverse, 10 speeds on the twist grip handle.
  • 8 Answers
SOURCE: Need wiring diagram
Call Minn kota, the number should be on the bottom of the head. They will e-mail it to you.
Posted on Nov 28, 2008
bigtor1976
  • 21 Answers
SOURCE: minn kota turbo35 electric motor only stays on full spped for 10 minutes.
I dont know how old your battery is but they will sometimes show full charge but not last long cause of age. Try a differant battery.
Posted on Dec 01, 2008
  • 10 Answers
SOURCE: Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
SOURCE: Minn Kota power drive trolling motor will not
It is the circuit board in the foot pedal. You will have to replace the whole foot pedal. This is a very poor design. The thin plastic which protects the contacts gets a little hole which allows water to enter and consequently the contacts corrode. Has happened to me two times in past four years. It might be OK for operation in a dirt-free water-free environment; but not under actual fishing conditions.
Posted on May 26, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Lookinf for a manual for a minn kota model 55d
    call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
    May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Have a serial # for minn kota trolling motor but is pretty old like 80's trying to find a parts diagram/prop serial is MK00367970
    Have you tried online with a "Minn-Kota" search? There are also Blogs with various titles that can help.
    Mar 12, 2010 | Boating
    Burning out fuses on trolling motor at battery
    not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
    Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Year made MKAD2674059 minn kota
    According to: http://www.northlandmarine.com/MinnKotaMotorControlBoardAssm.htm
    *Note: Newer model trolling motors have serial numbers beginning with the two-letter prefix MK (Minn Kota), followed by a two-letter year code. MKAB .......... 2001
    MKAC .......... 2002
    MKAD .......... 2003
    MKAE .......... 2004
    MKAF .......... 2005 MKAG .......... 2006
    MKAH .......... 2007
    MKAI ............ 2008
    MKAJ ........... 2009
    MKBA .......... 2010 A serial number with the designation MKAB denotes a
    2001-motor and MKBA would be a 2010-year model
    Jun 13, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
    You need your serial number of the trolling motor, length of shaft, and thrust poundage.
    or you could call Minn Kota direct and give them the same information at 800-227-6433.
    Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Install
    Click the link below, You do need to know your serial number thrust of motor and length of shaft as well how far away from trolling motor you will install your battery. This link is on Minn Kota Motors website under FAQ you can discuss with a service rep at Minn Kota please call 800-227-6433, but you will still need the information I asked earlier to come up with the answer.
    http://www.minnkotamotors.com/_ui/sramk08/tpl/sramk_nohero_banner_faq-item.aspx?id=145&__taxonomyid=977
    Apr 13, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Boating Logo
    268 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
