Question about Garden
I have a Talon blower vac leaf blower & it will not start easily What is the initial setting for the mixtute screws? it is a Model no AB3201 32cc petrol.?
I have a talon blower vac leaf blower & it will not start easily. What is the initial setting for the mixtute screws?
rwvanlue
  • 486 Answers
SOURCE: Talon Blower/vac 3201 doesn't rev high enough
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 16, 2009
  • 3600 Answers
SOURCE: Fuel Mixture Ratio Is it - 25:1 40:1 50:1
not sure if yo are changing the jets out but if your using the original screws and jets screw both screws in till they stop then turn 1 and a half turns out they try starting if it kicks and won't run then turn each screw another 1/2 turn out try starting if it runs rough adjust the gas jet a little bit till it runs smooth once it warms up give it full gas and you should get just a slight puff of black smoke to be set right, if it's too lean it will get hot and will be hard to start if it dies, if that happens then give it extra gas. once warmed up it should idle without dyeing if it dies adjust the idle screw up 1/4 turn at a time till it runs at idle without holding the gas trigger, be sure you replace the in line fuel filter and fuel line first then clean the air filter before doing any adjustments. most problems are caused by plugged fuel filter due to ethanol in the gas.
Posted on Mar 10, 2010
Testimonial: "sweet bro thanks 4 the extra tips as well"
Mike258
  • 1498 Answers
SOURCE: gmc petrol leaf blower
Believe it or not, I've had a lot of luck with local Goodwill outlets as a source for spare parts. You see a lot of what gets dropped off isn't exactly in tip-top condition and not resellable as-is.
I ask to see what they have and sometimes make an offer. They usually accept.
It turns out to be a win-win and there's nothing wrong with that.
Best of luck
Mike
Posted on Mar 23, 2010
Testimonial: "Hi I never thought of them. I will give them a try over the next few day. Thanks mate. Kindest regards Anthony"
rycgl
  • 1545 Answers
SOURCE: Where do I buy Replacement collection bag for
We have several choices to choose from here in the U.S., but I presume that you are probably in Austraila. I would like to be of more help. If you would want to get one from here, the shipping charges would be ridiculous. Post back if needed.
Posted on Dec 13, 2010
woobie dog
  • 1273 Answers
SOURCE: I have a gas craftsman
Hi, W/D here.
There should be a switch at the front of the machine that you can depress to break the power and shut the machine down. Most of these type switches will go to off only as long as you hold the switch down, then return to the run position when you let off of it. Take a closer look, and you should see it.
Best regards, --W/D--
Posted on Apr 07, 2011
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Blower does not turn on
Apr 03, 2014 | Toro Garden
Snow blower shorted out
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
I am having trouble adjusting the idling and mixture settings for my Talon Vacuum Blower AB3201. I can't get it to run smoothly.
screw both hi and lo in all theway not tight but firm and then back out 3 qurters of a turn. Make sure first that your air filter is clean. good luck
Jan 26, 2011 | Garden
I have a Toro 524 with Tecumseh engine, model 38040 8 0000640. I am rebuilding the carb and would like to know what are basic settings for idle and hi/low speed screws?
The high speed mixture screw is initially set at 1 & 1/2 turns out. Then adjust it to give good acceleration and top speed, while not closing the screw more than you need to. The low speed mixture screw is set at 3/4 of a turn out. Adjust that, to give a smooth idle. The 3rd screw, the idle speed screw, is set to give a low idle speed without stalling.
Jan 14, 2011 | Toro Blowers Rake and Vac - Electric...
Talon 32cc blower vac starting instructions
Hi and welcome to FixYa. I am Kelly
Wow what a challenge this was! The manual was misfiled under ELECTRIC Blower Vacs:
http://203.41.115.95/images/Manuals/ELECTRIC_BLOWER_VACS/AB3201.pdf
Starting instructions are on page 3 of 4.
Thanks for choosing FixYa.
Kelly
Customer service here:
http://www.talontools.com.au/html/about_talon.html
email
customer.service@husqvarna.com.au
Oct 10, 2010 | Garden
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
Garden Logo
824 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
