Error Code PO2 Sanyo Air Cond Aust
Error code PO2 comes up when turned on
5 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Wimdow Air Cond.
Sorry, that's a no. There are, however, window air conditioners made for casement style windows which are tall and narrow. I know GE used to have them. Check geappliances.com. There are also " portable " air conditioners which sit on your floor and vent through hoses to a window.
Posted on Jun 18, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
hvac1960
  • 2133 Answers
SOURCE: what does error code po5
P05-Current value sent from MDC on outdoor unit control PCB is low. No AC power input for 3
minutes or longer: pre-trip - 5
Solution:
1. Check R/S/T power.
2. Check inverter control PCB.
3. Check outdoor unit control
PCB.
Thanks.
Posted on Feb 11, 2011
reyjoshua07
  • 1157 Answers
SOURCE: air cond comes up with
Hi rod_hucker,
Just to add, H6 is an Outdoor Compressor motor position detection sensor error. You need an Inverter tester to check this error. You could also try this link for the manual, may not work but just give it a try.
Manual link
--> you need to create an account to be able to download the manual.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 14, 2011
I have a aircon that showing me the error code e3 on the display board. can you help me with this problem
Hi I googled (error code e3 for Sanyo 12000 Btu Mini Split Air Conditioner) and found this link below of a short youtube video of the answer you're looking for, Also on the right there are other video's you might be interested in...I hope this helps you..CHEERS..
https://www.youtube.com/watch?v=nISwqnhul90
Mar 22, 2016 | Sanyo 12000 Btu Mini Split Air Conditioner...
My Split sanyo Stop Work after 1 hour sometimes other after 15 minutes
Should give you an error code on the t-stat. That's the 1st step. If it doesn't then there is a way to display error codes via the t-stat or remote control. Find the owners manual for the air handler
May 29, 2015 | Sanyo Heating & Cooling
ERROR CODE BLINKING,THE AIR CONDITIONER DOESNT WORK
it is happening due to blower motor not giving the signal to pcb pls check their is a return signal wire in blower motor is broken or motor is defective.
Jul 20, 2010 | Sanyo Split System Air Conditioner
Mar 10, 2010 | Carrier Heating & Cooling
What are error codes E98 and F47 for 1992 Cadillac Deville
The E98 is P/N to D/R In ISC (Idel Speed Control) Range problem. This code will not trigger a service light.
The F47 is Refrigerent System Problem. This code turns on the Service Air Cond light, and switched the Climate Control from Auto to Economy.
Mar 01, 2010 | 1992 Cadillac DeVille
What does the error code VC/VH trip mean on a Bryant out door hp cond.
vC/vh Trip or code 6. The start cap and or the start relay is bleeding voltage to the comp in the off cycle. Replace both the cap and relay for the fix.
Jul 09, 2009 | Bryant Heating & Cooling
Sanyo Condensing unit. blower fan doesnt come on unless unit runs,but unit only runs for about one minute and shuts off. led #6on cond. unit blinks and led on evap. coil #26 also blinks unit needs to be...
First, the condensor fan is only supposed to run when the unit is on. As for the one minute run, then needing reset...this sounds like a "safety out". The air conditioner knows something is wrong and tries to protect itself. Being low on Freon would take about one minute to register. Do you have pressure gauges? The low pressure side should be about 65 to 85 psi with Freon 22.
Jul 24, 2008 | Sanyo Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
