Question about Video Cameras
Hi. I have a old sonny camcorder ccd-fx300e.It play but no image and the counter doesn't move. Thankx
SOURCE: SONY CCD-TRV138 8MM CAMCORDER
CCD-TRV138 Attempted to record or play. Not operating.
Posted on Apr 19, 2008
welcomejee
  • 10594 Answers
SOURCE: CCD Problem
would you like to tell me your county name? I will try to locate Sony service center in that area.
Posted on May 28, 2008
  • 19 Answers
SOURCE: no sound on playback
The S-video cable carries picture only. You need to also hook up RCA audio cables from the camcorder to the TV
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: drivers for ccd-trv608 HI-8
This is the only solution that I have found that really works. The only problem is you need access to a computer running XP. On the Sony website they have drivers for XP. The XP drivers work for Vista, but vista will not let you install them normally. So on an XP computer goto the sony website and download the xp drivers and install them on the xp computer. Then all you need to do is go into your C: drive and there will be a folder called "Drivers" in that folder you will see the sony usb folder. Just copy it, onto a disc or thumb drive. then copy the folder to your vista computer. You can put it anywhere, I jsut put it on the desktop for easy access. Then plug in your usb cable for the camcorder, let it try to install, then it will give you an option to sellect the files yourself, browse to the folder you coppied onto your desktop and Viola, Vista will find the drivers and install them. you now can use the usb connection on your camcorder.
if you are having a hard time finding the files, email me and I will send them to you.
austinpack@gmail.com
Posted on Jan 06, 2009
SOURCE: Need adaptor for older Sony analog camcorder - CCD-TRV70 DC 6V
You need to get a Digital to Analogue converter such as the Canopus ADVC110 A/D Converter. (circa $225). There may be cheaper alternatives. (you might also be able to use a digital camcorder that has a built in Analogue to digital converter):
 Canopus 77010150100 ADVC110 Converter
The Canopus comes with a 6-pin firewire cable. Since your Dell Studio has a 4 pin Firewire (actually called iLink) you will also need a 6-pin to 4-pin cable or an adapter:
 Firewire 6-PIN To 4-PIN Cable
 Cables To Go - 27028 - Firewire 6-Pin Female 4-Pin Male Adapter
You hook your Sony up to the A/D converter with audio and video cables (usually supplied with your camcorder) and hook the converter to you Dell with a firewire cable. Then you capture the video using some video capture software. I don't know what comes with windows these days.
Posted on Feb 18, 2009
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
I have sound and can view previously recorded videos on my camcorder. However, on Christmas morning my camera doesn't record or view images. It just records a black screen with white lines. The li
The recording head is probably the source of the problem and will need to be replaced, other than putting a dry cleaning tape or better still a new blank tape, allow it to play right through, it may work.
Mar 10, 2012 | Sony Handycam DCR-DVD105 DVD Camcorder
Hello i am trying to figure out why my sony handycam dcr hc30 ntsc will not sho picture when i turn it on all i can see is darkness but when i play back old tapes i can see the picture fine what should i...
Let me make it easy for you, your camcorder got ccd imager chip failure problem that is why you do not get live view in camera mode, replace ccd imager chip by local camera repair shop to solve this problem.
Hope this info will help you.
Thanks.
Nov 24, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
Opens and closes ok. until i put tape in ,just keeps ejecting.sony camcorder ccd-fx300e.ta
Hello, did you ever find a solution?
I have the same camera and exactly the same problem.
Aug 24, 2010 | Cameras
Not able to view anything through the lens. i can only play back earlier tapes recorded.
probably the ccd imager assembly has failed. The imager in this camera is reasonably priced and easy to replace
Jun 08, 2010 | JVC Cybercam GR-D70 Mini DV Digital...
Everthing seems to work, except the camera will not record.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
My camcorder can play old tapes but won't record
Your camcorder Sony DCR-HC20E has bad ccd imager problem and that part will be replaced to have live view to record on tape.
I can provide you ccd imager part number info if you want to repair it by yourself.
CCD Imager replacement in this camcorder requires expertise and fair skills of soldering parts in PCB.
Jul 11, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam Vision videoHi8 will record sound, but no picture.
It is known problem of bad ccd imager in camcorder and requires replacement of that part.
Sony will repair CCD-TRV318 Free of Cost in ccd imager problem.
Please click Sony CCD Imager Support for details.
Good luck.
Jan 27, 2009 | Sony Handycam CCD-TRV318 Camcorder
Video Cameras Logo
94 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
