Question about Frigidaire Kitchen Ranges
Why does my Frigidaire Model#RB-137C not turn off when knob is turned off
Model #RB-137C Serial #60CG3819
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Replacement knob
imsert your model number here, you can download a complete parts manual
http://www.frigidaire.com/support/manuals.asp
Posted on Jan 15, 2009
  • 497 Answers
SOURCE: I turn the knob on the front right burner and
its a valve issue, most likely needs repair.
Posted on Sep 02, 2009
I have a Marlin model 93 serial number 137c what is it worth
Check with ebay or find out at the public library catalog
Dec 21, 2015 | Optics
Frigidaire gallery self cleaning oven locked
Hello winterliones, thank you for your post!
I see that your have a Frigidaire range and the oven door is locked. May I please have your model number? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side.
In the meantime, try pressing the CLEAR/OFF or CANCEL button in for approximately three seconds if your range is a touchpad model.
If you have a knob type range control, I suggest starting a self-clean cycle. Then turn the stop time knob to the off position. If that does not work, then disconnect power to your range and reset it by either unplugging it or flipping the breaker off. It is best to wait roughly ten minutes and then turn on your range.
I ask that you please follow up with a response on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully.
Best of luck! - Z
May 18, 2014 | Computers & Internet
How do you unlock my frigdair oven door
Good Afternoon Anonymous, this is Z. I am happy to assist you!
I understand the oven door of your Frigidaire range is locked. May I please have your model number? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can help you unlock the door.
If you have a knob type range control, I suggest starting a self-clean cycle. Then turn the stop time knob to the off position. If that does not work, then disconnect power to your range and reset it by either unplugging it or flipping the breaker off. I suggest waiting roughly ten minutes and then turn on your range.
Hope to hear from you soon and best of luck!
Apr 26, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
How to turn beep off when transmitting
all the beep is for is so people can tell when you are done transmitting. There should be a push knob or button or just a plain old knob that has R.B. printed next to it . Turn it off.
Apr 12, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Door won't. open on frigidare convection oven #240462603 can you help?
Good Afternoon Karen, this you for your question!
I understand your Frigidaire oven (240462603) will not unlock. However, it appears above-listed model number is invalid. The serial tag, which lists your model number, is typically located in the storage drawer, on the right side.
In the meantime, I suggest pressing the CLEAR/OFF or CANCEL button in for approximately three seconds if your range is a touchpad model.
If you have a knob type range control, I suggest starting a self-clean cycle. Then turn the stop time knob to the off position. If that does not work, then disconnect power to your range and reset it by either unplugging it or flipping the breaker off. It is necessary to wait roughly ten minutes and then turn your range on.
Best of luck - Z
Mar 30, 2014 | Frigidaire Ovens
Replacement knob
Jan 15, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Instructions for frigidaire oven
an f1 one code means that
Electronic control has detected a fault condition. Turn the Temperature Control Knob to
OFF, and disconnect the power to the range. Wait 30 seconds and reconnect the power.
If fault recurs, disconnect the power and contact an authorized servicer.
You can get all the codes here in the manual.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FEF365BWD&User=&Search=Search
Dec 16, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Older Ceramatop GM Frigidaire oven stopped working-stovetop works
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Dec 10, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Front Load Washer FWFB9100ES1
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
