Question about Panasonic Televison & Video
What caused my TV to suddenly have pink and green areas on the screen?
    Top Expert:
  • Panasonic Master
  • 75,283 Answers
Hello
For every standard televisions, there will have a degaussing posistor, to demagnatise the picture tube, each time it is switched ON. If thie degaussing posistor has damaged, there will be no degaussing action and color patches on screen will be the relsult.
Moreover, check whether there is any external speaker boxes have placed near the Tv. The magnetic effect from the magent of the speaker can also cause this.
Posistors sre of severel types, and the pictures of some of them are given here.
What caused my TV to suddenly have pink and green  - 2_8_2012_4_10_49_pm.jpg2_8_2012What caused my TV to suddenly have pink and green  - 2_8_2012_4_11_47_pm.jpg2_8_2012_4_11_47_pm.jpg
Posted on Feb 08, 2012
3 Suggested Answers
ronaldo_ross
  • 1056 Answers
SOURCE: Toshiba TV colours wrong pink sky, blue clouds and green people??
Inside your TV there is like a loop of insulated wirings the loop around the screen. This is to demagnetized the tube. There is a varistor which looks like a thick coin with two leads on it, or sometimes it looks like a flat ceramic capacitor that control this loop of wire. When you first turn on your TV current goes through the loop of wires to demagnetize the TV then the varistor shuts off. Sometimes this varistor fails, causing smeard colors. You can also demagnetize the screen without opening the TV. Using a hand held demagnetizer. It can be purchased at some electronic parts store.
Posted on Jun 28, 2009
  • 8457 Answers
SOURCE: tv screen shows green/pink
Ur video board that connected to the CRT long neck(tv tube).Have burn,capacitors?Or cold solder socket pins connected to the crt tube,must resolder,might solved prob.
Posted on Oct 14, 2009
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 03, 2016 | Sanyo Televison & Video
Panasonic TH-42PD50Uscreen colors all appear pink and green
the colour sensor on the picture display may have lost functioning....as in case of plasma tv`s the they use transistors for colour ......so better call a technician from the related company and do a check up.....no other solutions i hope.....
Jan 02, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Laptop LCD/Display Problem, Green and Pink Tints???
Their are a couple things that could be causing this, My first thought is that the screen its self is damage. A LCD screen is composed of millions of tiny pixels so when some fails others will still work.
That other thought is that the GPU or video device on the laptop could be failing and creating video problems. Have you tried closing the laptop and opening it agian, this would help rule out a bad cable connection.
Dec 24, 2013 | Computers & Internet
The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-43HT20 43" Rear Projection...
Tv screen shows green/pink
Oct 14, 2009 | Televison & Video
KP-61HS30 Sony TV turn pink and green text is bowed
Check out CONVERGENCE GALLERY . If you see your symptoms you have a problem in your convergence amplifier circuits. Typical Sony Convergence repair requires disassembly for replacement of 2 ICs, sometimes a fuse or 2, then TV is like new.
It is much more complicated than changing batteries on your remote. Many consumers try unsuccessfully to do a convergence repair. I recommend finding someone competent to do it for a reasonable price. Typical repair shop charges may be from $400 to $650.
If you are in the Calgary area, call me. More reasonable rates.
easyab
Jul 31, 2008 | Sony KP-41T65 41" Rear Projection...
Sudden pink hue to faces
It sounds like you lost your green, try turning down your color all the way and see if the screen is B&W, if it is then you have a problem in the ry-by-gy processor. If tthe screen is not B&W then I would suggest the Green video driver on the green CRT is bad or in that area>let me know!
Mar 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Colour distortion on tv screen
as you say pink& green means red+blue= pink &green means you are getting all color like b+g+r so it requires adjustment only please call skilled person to do it.
Oct 01, 2007 | Televison & Video
PINK/GREEN SHADOWS, LINES
Here is what I was able to find out about your problem from sony: This issue is usually caused by some type of nearby magnetic interference, such as unshielded stereo speakers placed too close to the TV. These spots can be small or large and will normally be red, green or blue, but sometimes appear purple or pink. They normally occur on the sides or corners of the screen, but can also appear in the middle. To resolve this issue, move any stereo speakers or other electronic devices away from the TV; a minimum of 2-3 feet is recommended. If the situation is not remedied immediately, unplug the power cord of the TV from the electrical outlet for 20-30 minutes; repeat this process one more time if the issue is not resolved the first time. If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer in your area. Hope this is helpful:)
Sep 04, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
145 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
