Question about Video Cameras
Screen damage How to get the screen on my Aiptek camcorder replace
  • 734 Answers
The consumer electronics are not too rugged, luckily ebay sell parts camcorders or cameras and you can buy replacement parts cheaper that way. You need a small 000 philips screw driver to take it apart, many plastic parts are snapped together.
Posted on Feb 08, 2012
When I power up my Aiptek 720P camcorder the screen tells me the memory is full although I have emptied the memory
Try reformatting the media, if using an SD card, replace it with another and use a PC and format it FAT16 with a PC and USB dongle return it to the unit it should be OK, you may have to format again after you put it in sometimes too.
Oct 06, 2011 | Aiptek A-HD 720P Flash Media Camcorder
Hello, i have an Aiptek cam corder and the screen is cracked and now whenever i turn it on more and more blackness is creeping out of the crack and the top of the screen than before, is screen replacable...
i think you will have to buy a new camcorder because if it is creeping out like that it is probably the camera itself,well the crack has something to do with it also,but its the camera,if it was just a crack itself on the camera then you can replace it,if you didnt keep touching it after it cracked it probably would have been alright to just get a new screen,but now its messed up...
May 31, 2010 | Aiptek ISDV2.4 Flash Media Camcorder
The camera is burnt and now its all screwed up.
To put it bluntly, throw it away. Applying the wrong power to equipment can cause too much damage for reliable repair. Even if all the bad parts could be found and replaced, other parts will have been stressed and may fail later. Also it's very likely the circuit board has been damaged as well. Replace the unit, and be very careful to use only the proper adapter in the future.
May 27, 2009 | Aiptek A-HD 720P Flash Media Camcorder
I can't put mp3 songs on my IS-DV camcorder
there are two different models of this camcorder, are your sure your camcorder supports mp3?
Aiptek IS-DV 5 MP Digital Camcorder and MP3 Player does support MP3
Aiptek IS-DV Flash Media Camcorder doen not
regards
Nov 27, 2008 | Aiptek IS-DV Memory Card Camcorder
Users Guide
have u looked online at aiptek website?
Jul 04, 2008 | Aiptek Pocket DV 5900 DV Digital Camcorder
Aiptek digital camcorder
Plug unit into computer (USB), open LCD screen of unit, depress "video" button, when prompted on camera LCD, select "live."
May 21, 2008 | Aiptek DV5100M Camcorder
Solution for aiptek dv4100M
Sounds like this unit has worn out.
I have worn out 2 model 4100's and am now using a 5100. They usually give at least one year of service if used frequently and are pretty rugged. Recently ordered TWO refurbed 4100's from Aiptek for a total cost of $48.00.
Apr 27, 2008 | Aiptek DV4100M Camcorder
Wont read sd card..screen shows card locked..card ok
There is a little slide switch on the side of the memory card. Good luck!
Jan 02, 2008 | Aiptek IS-DV2 Camcorder
Camcorder lcd screen light blue (blank) and camera won't turn off...
Sounds like maybe a connection somewhere inside the camera came loose? Or maybe the camera's firmware (camera's operating system) is damaged? I'm honestly not sure what would cause this. You could try contacting Aiptek customer service or you could post this issue at http://forums.steves-digicams.com/forums/view_forum.php?id=92
and see if anyone there is familiar with this problem.
Nov 12, 2007 | Aiptek MPVR Digital Camera
Video Cameras Logo
61 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
