Question about Irons
-3x 2y = 0 what does x and y equal ? - Irons
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 29 Answers
X 0, y 0
(-3x0) (2x0)
0 x 0 =0
Posted on Feb 08, 2012
The electric element for the steam tank has failed can i get a new element
Of course you can. But is the price of the part low enough to justify it? Often the part price is equal to or greater than the price of the entire shebang.
Nov 23, 2015 | Irons
How many yards will it take to cover 30ft by 40 ft ,4inches deep
Do you mean how many cubic yards it would require to fill a volume occupied by an area of 30 ft by 40 ft by 4 ins deep? If this is what you mean then it would require 11.1 cubic yards. Hope this helps.Sorry I can't help with the cost.
Mar 26, 2015 | Pottery Barn Adair Floor Lamp, Bronze...
How to remove mineral build up fron steamfast sf-465
Alternatively, use in your steamfast
  1. Fill the steamer with an equal part solution of water and household vinegar and let this soak for an hour.
  2. Once the hour is up, shake steamer to adgitate
  3. Then, empty the steamer and add a couple cups of mixture through machine.
  4. If you don't have any vinegar to hand, try lemon juice!
Organic Cleaner White Vinegar For Calcium and Mineral Build Up
Removing Mineral Deposits from Household Surfaces
How to Remove Mineral Deposits
Apr 15, 2014 | Steam Fast SF-465 Iron
Does not heat up
Visual Check:
1. Do you smell burned electrical wire? If none,
2. Check the cord for damage, and the outlet for electricity ((plug in another device and see if it turns on)). If none,
3. Does the water reservoir or iron face have visible mineral deposits (i.e. need cleaning)?
Possible solutions:
1. On COLD, UNPLUGGED iron, clean working surface with non-abrasive cloth.
2. Try Vinegar & Water cleaning to remove mineral deposits (if warranty allows):
Mix equal parts water and white vinegar (abt. 1/3 cup each).
Pour into water reservoir.
Turn on the iron with steam option.
Allow to work, upright, for 2-3 minutes.
Turn all controls to low before unplugging.
Drain into sink ...carefully, it may be hot!
Flush with plain water.
Reheat iron and test on scrap cloth to clear any residue.
BE SAFE and work carefully. If iron still does not heat after thorough inspection and cleaning, the unit may need a qualified technician.
Dec 29, 2012 | Bosch Irons
Lost steam pressure
see this causes and fix it.God bless you
Inspect the steam vents from the outside, and use a pipe cleaner or other small utensil to remove any excess buildup that is blocking the vents. Be careful not to let the buildup fall down into the steam vents.
  • 3 Clean the steam iron's directional spray tip. Minerals and other debris can build up on the nozzle over time and will greatly hinder the use of your steam iron.
  • 4 Pour equal parts vinegar and water into the steam iron's water supply tank. Put the steam iron above an empty pot, and turn the iron on. Let it steam the solution until all the water/vinegar solution is gone
    Sep 23, 2012 | Tefal UltraGlide Easycord FV4256 Iron
    Bottom of iron has scale build up
    Sounds like you need to clean the iron. Try equal parts of white vinegar and distilled water. Fill the reservoir with the mixture, turn iron to highest setting and place the tron on a wire rack in a baking pan lined with ab old towel. Repeat if needed, Rinse iron with a cycle pf distulled water. Clean iron in a ventillated area since vinegar odor will be strong.
    May 27, 2012 | Rowenta DG-980 Iron
    Can I use a descaler on my Tefal Ultraglide as the anti scale isn't working
    Yes just use equal parts Vinegar & Water and fill as usual, and work through.
    Apr 02, 2010 | Tefal UltraGlide Easycord FV4256 Iron
    Iron will not heat up when it is on. The lights come on when plugged in but not the heat.
    Your electric iron probably has an open heating element.. Probably not worth repairing.. since thecost to repair might be equal to the cost to replace.. Wrinkled clothes are making a comeback... ( at least .. in my house..LOL) Good luck my friend !
    Sep 04, 2008 | Westinghouse Irons
    How to use steam iron
    Fill the iron with equal parts white vinegar and distilled water. Place an oven rack over your sink and position the iron on top, with the steam vents facing down. Plug in the iron and turn it to the steam setting. Run it until the steam stops.
    Feb 23, 2008 | Micro Pro 7599 Iron
    Iron Cleaning
    If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
    Feb 12, 2008 | Irons
    Irons Logo
    Top Irons Experts
    Are you an Iron Expert? Answer questions, earn points and help others
