Question about Water Computers & Internet
Ford bantam 2004 1.3
How to bleed the system
  • 17,970 Answers
To bleed the system all you need to do is remove the cap from the radiator or overflow tank and allow the engine to tick over for 10 to 15 minutes. Ensure the heater dial is set to max and fully turned on when doing this. This will expel any air that is trapped in the cooling system. Top up the coolant as the air is expelled.
Posted on Feb 08, 2012
What's your question?how do i bleed powerstering pump for 2004 ford bantam
easy fill resevoir then turn steering full lock left to right about twice ,check fluid level ...job done
Oct 06, 2015 | Ford Cars & Trucks
Bleeding the clutch
2 people job. one presses down on the clutch pedal while the other opens the bleed screw. then closes of the bleed screw before the pedal operator lets the pedal up . The process is repeated until all the air is out . Watch the fluid level in the reservoir.
Mar 11, 2014 | 2006 Ford Bantam 1.3i
Hissing noise from reservoir on ford bantam 2009 1.6i
air in the system .put your heating on full .to bleed the heater.remove the expansion bottle cap .run the engine push in the hose from your radiator with your fingers to get the air out your bottle and replace your cap.
Dec 18, 2013 | 2005 Ford Bantam 1.3i
Fuse box layout on ford bantam
On this website (link below) you find fuse box diagram and description for Ford Bantam
Ford Bantam 2002 fuse box diagram Auto Genius
Oct 15, 2012 | Cars & Trucks
How to bleed n Clutch system on Ford Bantam 1.3
I have a Ford Bantam 1.3 bakkie and the clutch fluid is running / leaking into the vehicle itself. How do we replace?
May 03, 2012 | 2006 Ford Bantam 1.3i
Hi,I have a Ford 2004 Bantam 1.6i XLE. The airbag light keeps flashing,after a while it stays on constantly...possible faults or solutions?
You must have the fault code read that is recorded when the light flashes. Have the system canned by the dealer.
Feb 16, 2012 | 2005 Ford Bantam 1.3i
Overheating on ford bantam
there are three probable causes that may result to overheating one inadequate circulation of coolant within the cooling system. The radiator is clogged with dirt some stems are closed.try to flush the radiator using rad flushing fluid. Second improper bleeding of trap air within the cooling system. Third the water pump blades are worn out inadequate circulation of coolant.
Feb 02, 2010 | 1996 Ford Bronco
Computers & Internet Logo
184 people viewed this question
Top Water Computers & Internet Experts
richie46
Are you a Water Computer and Internet Expert? Answer questions, earn points and help others
