Question about Gateway P-7801u NoteBook Intel Core 2 Duo P8400 17.0' Wide UXGA 4GB Memory DDR3 1066 320GB ...
My p-7901U FX made a popping sound, turned off completely (crashed) and now won't turn on. After unplugging everything from the laptop and wall sockets, I plugged the power adapter into the wall
I also tried the reverse order of plugging the adapter into the laptop first, then wall socket with no change in outcome.
    Guru:
  • 1,705 Answers
It looks like you had a component burn out somewhere. Save dismantling it and checking for component failures try contacting the Gateway support site:-
http://support.gateway.com/s/Mobile/2009/PSeries/P-7801u/P-7801unv.shtml
Posted on Feb 08, 2012
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
Why can't i turn my laptop off?
Unplug charger from laptop and remove main battery, press power for 60 seconds, when completed hook everything back up.
Jun 17, 2012 | ASUS Eee 2G Surf Notebook
Hp pavillion dv9815 won't start. it just reboots over and over. shutting down each time.
take out the battery, then take out the memory. Put one of the two memory modules back in, and turn it on. If everything looks ok, shut down and put the other one back and try again...if everything is ok...then ok. If it doesn't work after the first one, let me know...
Jun 11, 2012 | HP Computers & Internet
Laptop Fan and Power Indicator won't turn off.
Are you sure you are turning it off completely. Sounds like you have it sleeping or hibernating. Press and hold the power button for 15 seconds or so, it should power off completely.
Mar 29, 2012 | Computers & Internet
Computer ramdomly turns off
Instead of unplugging everything, only unplug 1/2 of the things. If it still won't start, unplug 1/2 of the remaining things (noting which ones they are). If it restarts then, it was one of the last set of things you removed that is the problem, so keep eliminating possibilities in this fashion this until you can determine which component it was. If it turns out to be the power cord, it could be a problem with the power supply.
Mar 02, 2012 | HP Computers & Internet
Won't turn off
Unplug it directly from the wall & if it still wont turn off then you'll need to find the portal to the Otherside and go there and unplug the poltergeist version of your TV from the wall as well. This should fix it.
Oct 18, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Acer aspire 1710 msi laptop makes popping sound when turned on won't start
Popping sounds are bad. Usually shorting electrical somewhere. Is the light on the power brick green? flashing? Red?
It's either a bad power brick or a bad connection in the laptop. You can buy a power brick fairly cheap, but if its out of warranty and the problem is not in the brick its probably not worth it to fix.
Jun 28, 2011 | Acer Aspire 1710 Notebook
Gateway P-7801u NoteBook Intel Core 2 Duo P8400 17.0' Wide UXGA 4GB Memory DDR3 1066 320GB ...  Logo
59 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
