Question about Hotpoint Washing Machines
Wlw3600 shake bad while in spin cycle - Hotpoint Washing Machines
fanny
  • 146 Answers
SOURCE: Bad shacking during the spin cycle
Remove top of machine and check the centralising springs are still attatched. If springs ok tilt machine against the wall after unplugging from the wall socket and check the shock absorbers. One of them could have jumped out of the guides. If shockies are ok, check the spider for cracks/breaks. The spider is the cast part that holds the outside drum in place. To check this you will have to remove the back plate.
Posted on Nov 05, 2007
  • 20 Answers
SOURCE: Matag washer Performa shakes badly on spin cycle
Ensure the washer is level by rocking it. If its level should'nt be able to move. You may have a weak floor. to checks this look to see if anything is vibrating around the washer.
Posted on Feb 10, 2009
  • 109 Answers
SOURCE: shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
Posted on Mar 29, 2009
SOURCE: whirlpool washer machine shakes badly when cycle
The problem could an improper leveling of the machine.Also could be bad drum bearings or even damaged ones because of the previous heavy spins.
Posted on Apr 08, 2009
  • 2468 Answers
SOURCE: my maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Posted on Apr 02, 2010
I have a whirlpool washer sm9280469 that shakes bad on spin
not a good model number,if it's very loud in the spin cycle the spider gear is bad and you need a new washer,watch video
http://www.youtube.com/watch?v=Uud3xDus4TQ&feature=related
Mar 28, 2013 | Whirlpool Washing Machines
WTW4800xq0 shake bad during spin cycle
My washer was just doing the same thing shaking like crazy on spinning cycle whirlpool model WTW4800xq0 I just change the 4 suspension spring balancer rods part #W10820048 and it work like new againg search amazon cheaper than sears easy to change I hope this help some body and save money this parts cost $50 dollars on amazon
Dec 01, 2012 | Whirlpool Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Kenmore Washing Machines
Shakes on spin cycle
yes bad struts can cause this problem also if you have it on carpet you would be better off cutting a piece of plywood for it to sit on as it will shake when sitting on carpet most of the time
May 19, 2009 | Maytag Neptune MAH7500A Front Load Washer
Whirlpool washer machine shakes badly when cycle
Apr 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Shakes during spin cycle
Mar 29, 2009 | Washing Machines
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Washing Machines Logo
47 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
