I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found : First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
After a lengthy period of inactivity, we came to use the dehumidifier and noticed that the LED...
(More)
After a lengthy period of inactivity, we came to use the dehumidifier and noticed that the LED screen was no longer lit. As a result we cannot see the settings.
I have been emptying the tank few times a day, because I had no convenient drain in basement. Now, I...
(More)
I have been emptying the tank few times a day, because I had no convenient drain in basement. Now, I have a drain and can connect garden hose to the back of machine...but I have misplaced my remote and manual. What must I do to make it work? Thx.
Model DDR6588EE - called Danby and they will not tell me what part I need or how I can order it due...
(More)
Model DDR6588EE - called Danby and they will not tell me what part I need or how I can order it due to liability associated with electrical work needed. Authorized service people will charge at least $120 (all-in) to diagnose what sensor it is, order sensor and repair it...bottom line is that i think i need to get a new one (NOT A DANBY)... if anyone else has any ideas on a solution, please let me know...
My unit is collecting moisture VERY WELL! BUT it blows warm air only which makes it very hot in our...
(More)
My unit is collecting moisture VERY WELL! BUT it blows warm air only which makes it very hot in our apartment - anyway I can get it to stop blowing warm air from the top??
