Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Blinking not mounting? - LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
  • ayannacalhou
    ayannacalhou Feb 08, 2012
    Thank you! Sorry I wasn't very descriptive with the problem. When I turn it on it blinks (blue light) instead of staying on and I also hear a clicking noise. After reading some comments on other questions I also listened closely to the power adapter and hear the same noise slightly higher pitch. I'm thinking it may be the power adapter?
    Sergeant:
  • 233 Answers
If you are a front usb port on your desktop , switch to rear one. or try it on different pc, if aproblem continue that means that the usb controller on your external HDD is malfunctioning , you should have it fixed or replaced with exact same one
Posted on Feb 08, 2012
My tv blinks one time then one time fast what is the problem
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 17, 2014 | universalmounts New Universal Premium Wall...
CHH012CD-13B
This type of unit does not drain into the outside unit. It drains into a nearby interior drain, or just to the outside near Inside unit. If the unit is cooling properly, you're ok.
Jul 01, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
Panasonic led viera power light blinks 10 times then stays on no power
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 29, 2014 | Universal 40-42 Inch Flat Screen Panel...
AIRBAG LIGHT ON CODE 4 blinks then 5 blinks then stays ON
| 44 RH Crash Sensor - Not Mounted to Vehicle Properly
| 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
| 46 LH Crash Sensor - Not Mounted to Vehicle Properly
All Ford codes are the same, as far as I know there is no center sensor, there are two on either side of the grill.
Sep 13, 2010 | 1996 Ford Explorer
Rear light blinks but new flush mounts dont
Did the fluch mounts come with a resistor?
With a multimeter, check the resistance (Ohms) between the original blinkers and the new ones. You may need to add a resistor to make them the same so that they blink.
Oct 14, 2009 | 2007 Yamaha YZF-R6
My keypad works,my remote opener does not, even
It is related. One of the buttons on your wall control is the lock button and has a lock icon on it. Press and hold it for 3 seconds. The blinking should stop and your remote should now work.
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sony KDS-R60XBR1 bLINKS 6 TIMES
When I try to look up blink codes I'm getting conflicting info. On this model is the lamp on side of TV? If so 6 blinks is showing as lamp door error, the micro switch the lamp door makes contact with is either not closed all the way or possibly defective.You can try reseating door or check the switch and wiring connections coming off it. You could try temporarily by-passing the switch by making your own short across the plug it connects to.
If the lamp mounts in front 6 blinks is a defective thermal fuse.The fuse is mounted right next to the lamp.From the back you can disconnect the plug for the fuse and check for continuity if its open its bad.
Apr 30, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
56 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
