Question about Diesel Miller 907218 Trailblazer 302 Welder Generator
My 302 diesel trailblazer runs for a few minutes then shuts down and flashes HI H20 code ,the manual says its a coolant issue but even with the proper amount of coolant it still does this
    Problem Solver:
  • 5 Answers
You need to "burp" you're coolant system. To do this find the upper Radiator Elbow where it goes into the engine, then, use an allen head to unscrew bleeding screw (for lack of better term). place Rags under so as the spilling coolant is caught as best you can (it's basically a fill bolt style, fill radiator until coolant seeps from that hole, lock her back up, repeat testing.
- Logan P. Clayton
Miller Authorized Service Technician
Posted on Oct 12, 2016
Engine codes 1415 and 1345 on a 2002 4.2 chevy trailblazer ls
1415 secondary air injection system bank 1
1345 crankshaft position-camshaft position correlation
You have something wrong with either your camshaft or crankshaft sensors. That's why car won't run
Jul 06, 2017 | 2002 Chevrolet TrailBlazer
My TB 302 cranks and runs at high idle does not idle down. I have power at all recepticals but no power at welding leads. I have checked all breakers and fuses, they are ok. what do I need to do next
there are a few things you can check on your machine,
make sure your machine is not in the remote control position, make your process switch is in the electrode hot position, the trailblazer has three slip rings, make sure the carbon brushes are not "stuck" in the holders, there are 2 circuit boards in your machine, make sure the plugs are properly inserted into the receptacles and making good contact, also make sure your ignition switch plug is clean and making good contact
Mar 17, 2016 | Miller Trailblazer 302 AC/DC Welder...
How long can a musso 622 engine run without water
Hi Stefan:
I would not even consider trying to run the engine without coolant.
Diesel engines run hot and the engine will be ruined if run without coolant.
Sep 18, 2015 | Cars & Trucks
How do I remove the knob on the front panel
put a little white lithium grease on it and push in and out a few times .do not take control knobs off if it ain't broke
Sep 13, 2014 | Diesel Miller 907218 Trailblazer 302...
I need the part number for the termial output and ground for my 302 diesel Trailblazer and a part number for the starter motor for my 400P Big Blue Diesel. Also any suggestions on spare parts I should...
Hi:
Part number for the ground output terminal is MIL 039046, list price is $24.34.
For the Big Blue need to specify what engine/model does your machine has or serial number.
Aug 07, 2011 | Miller Trailblazer 302 Welder Generator...
What does the code on my miller trailblazer 302,004 mean?
Hi:
That's not a code, 004 means the working hours left before the next oil change.
The display always start at 100 and count down all the way to zero.
If you don't change the oil and reset the count down you will start seeing negative numbers, meaning that oil change is due.
To reset the counter once you change the oil do the following:
Cycle engine control switch from the Run/Idle to Run position 3 times.
If this was useful to you, please vote. Thank you..
Mar 23, 2011 | Miller Trailblazer 302 Welder Generator...
My 2009 trailblazer 302 with kubota diesel engine keeps shutting down read out says lo oil. but engine oil dipstick shows full dobrodoc@starband.net
If you have owners manual I would locate the low oil safety switch and replace it. You can temporarily bypass the switch to verify that is the problem before buying new parts but I would not leave it that way. Use for diagnostic only. Thank you
Dec 02, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Rule 1800 gph pool cover pump will not run
The sensor that checks for h20 every 10 seconds may not be working properly. First make sure the pump is unplugged then clean the pump making sure the impeller is free never do this with it plugged in. tap the pump lightly with a screw driver handle to make sure the bearings are not frozen if it still does not work send it back to the manufacturer
Mar 20, 2009 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Diesel Miller 907218  Trailblazer 302 Welder Generator Logo
204 people viewed this question
Top Diesel Electrical Supplies Experts
jdthefixer
Joseph Mueller
Joseph Mueller
cwradio73
Are you a Diesel Electrical Supply Expert? Answer questions, earn points and help others
