Dell demension 2350 shuts down after a couple minutes what is wrong?
Computer will come on and will not get further than xp screen and then is shuts down.
    Guru:
  • 1,705 Answers
Could be a couple of things, but at a guess, there's a problem with XP. Switch on and press the F8 key several times while its booting.
This should give you several boot options, choose "boot in safe mode".
Once active click on Start - All Programmes - Accessories - System tools - System recover. It will offer you a choice of dates to recover your system from, choose a date prior to your problems, then leave it to get on with it.
If that doesn't work. It could be a component failure. Does it let out a series of beeps as it closes down. If so check the beep code given by your PC against the beep code list on this site:-
http://support.dell.com/support/edocs/systems/dim2350/advanced.htm#1217764
It should point you in the right direction.
Finally, if you feel confident, take the case off and give it a clean out with a dry paint brush and hoover. Take care not to disturb any components or cables.
Posted on Feb 08, 2012
  • 669 Answers
The most likely situation is a file error in the windows boot up process. Try booting the computer in safe mode (press the f8 key after the post screen, and selection menu will come up, sellect safe mode). If it does not boot this way, you could try a boot repair (since you did not list tthe brand model of computer, it is hard to direct you on this course). Most likely you will have to do a full restore to clear the error. This of course will remove all software, data that was not installed on the computer out of the box.
rahul26485
  • 611 Answers
SOURCE: Dell 2350 Demension
http://www.google.co.in/search?hl=en&q=Dell+2350+Dimension+Tower+power+problem&meta=
go to it you get it.
Posted on Jun 21, 2008
  • 61 Answers
SOURCE: I have a Dell Demension 2350 tower stuck in DOS safe mode.
restart the system by pressing the power button for 5 to 7 sec and hit the del button to enter the setup and load default setup and run an dell diagonastics
Posted on Nov 25, 2008
  • 131 Answers
SOURCE: Dell 2350 Won't boot up without cd
Check the jumper on the back of your drive. Chances are that the jumper is either on "slave" or "cable select". Change the jumper to master, and try rebooting.
Posted on Mar 13, 2009
rjblittle
  • 54 Answers
SOURCE: dell dimension 2350 shuts off after a few minutes
You could try opening the pc and blowing out the dust.
Posted on May 09, 2009
whitebirch
  • 433 Answers
SOURCE: desktop cpu shuts down shortly after startup
I if you haven't added any new hardware or software since this problem started check the following:
I would be thinking a heat problem. Check on the BIOS log looking for Thermal Events...check to see if the fan on your processor/sync. is tight and spinning. Check to see all fans are spinning and clean out dust. If you are satisfied that that is not the problem, look to your video card. Do a reinstall or update on the Vid drivers.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_CEL_2350&os=WW1&osl=en&catid=&impid=
It should be one of these two things...if not memory would be my next concern.
Posted on May 10, 2009
Need graphics driver for dell demension 2350
http://dell.driversdown.com/dell-drivers-list/s_613_1.shtml and scroll down to the list.
Jul 27, 2012 | Dell Dimension 2350 PC Desktop
Dimension 2350, on stARTUP ONLY
Remove the power cord, remove the case and look inside the computer at the capacitors. See if any of them are busted or leaking corrosion. The capacitors look like little battery towers but they are not as tall as AA or AAA batteries.
May 02, 2012 | Dell Dimension 2350 PC Desktop
I have a dell 2350 with windows xp professional 1-2cpu what new do i by to re load it the same . peter PS have lost the lot so have to by a new windows
According to the question above you are looking to reinstall Windows XP. You would need to gain a copy of Windows XP from a local electronics store. If you have a repair CD for the Dell 2350 then you would be able to insert this, then restart your computer. Once your PC restarts it will provide you options to restore your PC. If you require any further assistance, feel free to contact us at info@custompcrepair.org
Jan 31, 2011 | Microsoft Windows XP Professional
Dell dimension 2350 pc turns off and on repeatedly
Sounds like a bad mobo. 8 years! Damn let it die already LOL..!!!
Feb 21, 2009 | Dell Dimension 2350 PC Desktop
Adjusting the screen resolution
Right click the desktop > Properties > Settings Tab, you can change the resolution in there.
Jan 02, 2009 | Dell Dimension 4600 PC Desktop
Nov 21, 2008 | Dell Dimension 2400 PC Desktop
No sound on my dell dimension 2350 pc desktop
Go to this Dell link and download the Audio driver:
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2350 PC Desktop
Dell dimesion 2350 pc
Please go to this link for the driver.
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R64645&SystemID=DIM_PNT_CEL_2350&servicetag=&os=WW1&osl=en&deviceid=3597&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=84196
This is for Windows 2000 and XP, please make sure you are using one of those operating systems before proceeding.
If you need further help, come back and we'll try to answer questions you may have.
Apr 07, 2008 | Dell Dimension 2350 PC Desktop
Trying to set up a network printer with DELL TRUEMIBILE 2350...please help
using windows xp on all the computers, when you connect to the printer windows should automatically install drivers.
1. Goto My Computer, Click My Network Places (Explorer Bar).
2. Click View Workgroup Computers (Explorer Bar)
3. Find the computer that has the printer physically connected to it, open it
4. Find the printer and right click it!
5 Select Connect... and wait for the drivers to install.
this should install the print drivers and install the printer on your computer. the printer should now be available in print dialogs i.e. word etc etc and from the Control Panel > Printers window.
Nov 03, 2007 | Dell Wireless 2350 Router
Computers & Internet Logo
David Payne
David Payne
