How can i reboot my emachines computer with out the disc
  • 27,725 Answers
Restart your computer now as soon as you hit the power button keep on holding Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console select full factory restore and follow on screen instruction
(Note:this will erase all datas on the computer)
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Posted on Feb 09, 2012
2 Suggested Answers
  • 328 Answers
SOURCE: can't find my startup disc for my emachine, is
yes windows xp potable CD will solve it but select boot from CD ROM rather boot from floppy disk or you can use windows xp on bootable flash memory or you can restore your windows it might work
Posted on May 23, 2011
I have a eMachine t5246. My hard drive went bad, very bad, couldn't get it to even get wiped out so. my eMachine disc won't start up. It is the operating disc but every time it says install and...
If the hard drive failed you will first need to replace it with a working hard drive. One that is done, power on the computer with the recovery disc is the drive and enter setup. It should say something like press F9 or F10 for Setup. Look through the menus for "Boot Order", make sure your CD/DVD drive is above hard drive. Save the changes and reboot, you should get a message "Press any key to boot to disc" or something similar, do so, and follow the prompts to re-install windows.
Jul 07, 2013 | Computers & Internet
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
Can't find my startup disc for my emachine, is
May 23, 2011 | E-Machines eMachines Desktop PC
Can you play PC DVD ROM on an emachines E4026 Desktop PC. because i just had a game brought for me & when i try to load it , the computer reads it as a blank disc Any help appreciated ...
Based on the one and only specs sheet I could find for this model of emachine, it does have a DVD-ROM drive. So in theory it can. Does the unit play DVD Movies? if yes then it should work, try rebooting and then putting the disc in again. I assume the disc is clean and scratch free as the game is new.
If the OS on your computer has ever been reinstalled, you may be missing the driver for the drive, in which case windows would treat it as a generic CD-ROM drive, and not be able to read DVDs, you can get the drivers for the drive from the emachines website if this is the case.
Dec 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
I was trying to create the Recovery Management disk but everytime I try to burn the CD it keeps ejecting. I would really like it if you could provide some help. I recently bought this E-Machine computer...
Welcome to Fixya
Please see procedure below on how to create recovery disk. Let me know if smae thing will happen.
  • 1
    Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
  • 2
    Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
  • 3
    Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
  • 4
    Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
  • 5
    Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
  • 6
    Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
  • 7
    Set up Windows Vista with your own personal settings.
  • Thank you for using Fixya!
    Dec 04, 2010 | E-Machines emachines (emachinees) CD-ROM...
    Yesterday my friends emachine ET1331G-03w just bought 2 months ago, due to microsoft software updates issues upon restarting her computer won't start windows due to problem above, we tried to do f8 on...
    As the computer is only 2 months old, you should be able to contact Emachines and have
    them send you a recovery disc out for the particular model. As the computer may seem identical, in most cases a recovery disc from your computer will not work because of a different
    driver or some other small issue.
    Feb 12, 2010 | Gateway Computers & Internet
    EMachines PC that has not yet been thrown out the window, but....
    If this computer came with XP Home, and you don't have a disc, then they would have put the restore files in a separate partition on the hard drive. Do you have the manual for the pc? It's possible to recover your system without losing everything. What happened when you used the recovery disks and XP Pro?
    Aug 23, 2008 | E-Machines eMachines Desktop PC
    Cant get internet
    ok call your computer manufacturer let them no ,then call your internet service provider and also try to use any other disc.
    May 28, 2008 | E-Machines eMachines Desktop PC
    Computers & Internet Logo
    David Payne
    David Payne
