Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Open Washer Open top of Washer to get to tub
  • Whirlpool Master
  • 2,696 Answers
What problem are you having?
Posted on Feb 08, 2012
Our whirlpool cabrio washer model wtw8500dc0 will start a cycle. It shows error codes E9 F7 what is the problem?
you either have a bad motor or a piece of clothing is stuck between the tubs,open the lid and see if the tub will spin,if not clothes got down between the tubs.also check the wires down near the motor,sometimes the snap inside the casing from the tub going off balance,if there is a piece of clothing stuck between the tubs you pop off the top plastic part on the tub but first you have to get the top of washer off to do this,usually the clothing will be in the back right side,the metal might be sharp on the tub,i use a coat hanger to hook the clothing and pull it out,good luck and hope this helps,go here to see error codes.
http://www.searspartsdirect.com/washer-repair/error-codes/whirlpool-2015-cabrio-top-load-washer-error-codes.html
Sep 26, 2017 | Whirlpool Washing Machines
Clothes get tangle around agitator
unplug the power. open the top of the washer to expose the tub. Hold on to the top layer of clothing and rotate the tub by hand in the direction that untangles the clothes.
Nov 02, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
How do i open the top of my kenmore washer to replace a part?
There is two spring like clips in the front of the washer. Use a thin scraper. You have to start prising up on the top and push the clips back with the scraper and it will pop open. they are about two inches from each side, approximatlly.
Dec 03, 2011 | Kenmore 24032\24036 Top Load Washer
It makes a loud noise when washing - it seems like the inner tub is sagging or something, when you open the door you can see the top rim of the tub. Is this fixable - and cost effective?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 06, 2011 | Frigidaire FTF530FS Front Load Washer
I have a ge top load washer that the tub is off balance.
Open the control panel to get the mini manual. It will show how to remove the front panel and check the tub supports.
Feb 15, 2010 | GE Profile WPRE6100G Top Load Washer
Frig front load washer GLTR1670AS too much play in tub
Remove the kickplate and inspect the 2 tub shock absorbers, it sounds like they might be broken. If the tub is hanging to one side or dropped all together, remove the top and check the tub support springs.
Feb 23, 2009 | Frigidaire GLTF1670A Front Load Washer
My washer leaks occasionally from the back
ok i need a lilttle help from you,,,ok,,,open lid..take your hand and put it on the top of the agitator,,push the hole agitator and tub back,,and let it go if the tub stays back and does not come back center by its self,,your counter balance spring broke,,no mattter which way you push that agitator it shoud come back to near center..what could be bad counter balance springs ,,or tub surport springs.if you need help removing and changing please post
Dec 03, 2008 | Kenmore 15864/15862 Top Load Washer
Maytag top load washer leaks from bottom
usually tub seal ck pump and hose to pump but my bet would be tub seal
Apr 24, 2008 | Washing Machines
How do I get to the inside?
http://www.searspartsdirect.com/partsdirect/index.action go here enter your complete model number and will give you diagrams and parts list
Feb 15, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Calypso Top Loader
The wash plate (or nunater) can be removed by following these instructions. It may seem like a lot, but the wash plate will not come out of the tub unless you follow the necessary steps: 1. UNPLUG THE WASHER. 2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. 3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal. 4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it. 5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Your clothing is probably tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Good luck to you and I hope this helps you. PS Don't forget to put the tub ring back in.
Sep 18, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
